Hi Everyone,
Both showers are 8-year-old and had worn out grout/silicone and even some areas grout missed and silicone lifting off. So, I had regrouted and re-siliconed last year.
We have been using since last year with no obvious leaks.
Yesterday we identified high moisture readings in both shower bottom row tiles and a swollen architrave in one of the shower corners, as part of termite inspection. I have attached his photos and comments.
I'm not sure whether that moisture was already penetrated before I did reseal last year or after my work - no idea.
First thought for me was engaging leak detector but that is like artificially stressing the shower beyond normal conditions (by filling with water and eventually opening the leak points which would not happen in general use).
Also, my resealing work may not be 100% perfect, which may worsen the showers.
Can someone guide me what should I do in this case please?
