I have a 600mm oven cabinet and a Bosch HBA534BS3A oven — without unpacking the oven in case i need to return it — the dimensions listed on the oven indicate it wont fit in the 600mm cabinet. Any advice is greatly appreciated Thank you
Hello @MummaDaisy
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your oven.
Using the Kaboodle oven cabinet as an example. The interior space of the cabinet is 568mm wide from left interior wall to right interior wall. It is 560mm deep outer edge to outer edge, and it is 688mm from interior top to interior bottom. Please remember that Kaboodle oven cabinets have lifting timber gluts to lift the oven into the centre location of the cabinet.
Based on the measurements shown on the Bosch website. The HBA534BS3A requires a minimum width of 560mm+8 and a depth of 550mm minimum and a height of 600mm, which the Kaboodle oven cabinet easily meets. But just to be sure you can speak to your electrician and oven provider about the interior oven size. Please do not be confused with the exterior measurements of the unit.
The oven once installed will sit proud of the cabinet as its faceplate is meant to cover the sides of the cabinet. The oven panels are then trimmed to fit the top and bottom of the cabinet giving it a flush appearance. This of course depends on the type of oven cabinet you are using as I am referring to the Kaboodle oven cabinet as an example.
