Hello Bunnings Community,
I need some help to fix water leaks in bathroom shower screen and washing machine.
For the shower screen, there are two gaps that I need to fill. The first gap is shown in the first two attached photos. It seems to me that the shower door seal is not fitted properly that creates a gap between the door and the hob. How do I seal it properly?
The second leaks is shown in the third and fourth photos. It shows the inside and outside of the same spot where water is leaking from. I am not sure how do I repair this to stop the leak.
For the washing machine, it is leaking from the drain hose where it connects to the p-trap. The rubber end on the drain hose has threads and I screwed it onto the plastic hose. The clamp and the rubber are both hand tightened. However, when the washing machine is draining, water leaks from where the rubber end connects with the hose. And the water leaks more vigorously if I tighten or loosen it more. The best I can achieve is making it leak in droplets. Are there ways to make this end watertight?
Sorry for creating this long thread but I could really use some help from the community. Thank you so much.
Howard
