We transformed an unused patch of lawn into a modern, low-maintenance outdoor entertaining area featuring large charcoal pavers laid in a diamond checkerboard pattern with decorative pebble infill. The project involved excavating the site, preparing a compacted base, installing steel edging, laying over 100 pavers and creating a dedicated fire pit area with matching wood storage beside our new shed. The result is a practical, durable and stylish backyard space that has completely changed how we use our yard, providing the perfect place to relax and entertain family and friends.
- Brighton Masonry 400 × 400 × 40mm Charcoal Mypave 444 Paver
- https://www.bunnings.com.au/brighton-masonry-400-x-400-x-40mm-charcoal-mypave-444-paver_p3451984
ANL 1 Tonne Loose Road Base
- https://www.bunnings.com.au/anl-1-tonne-loose-roadbase_p0124988
BC Sands 1 Tonne Bulk Bag Paving Sand
- https://www.bunnings.com.au/bc-sands-1-tonne-bulk-bag-paving-sand_p0760315
Saxon 1.8 × 10m Non-Woven Weed Control Mat
- https://www.bunnings.com.au/saxon-1-8-x-10m-non-woven-weed-control-mat_p0831168
Jack Weed Mat Pins (20 Pack)
- https://www.bunnings.com.au/jack-weed-mat-pins-20-pack_p3048532
Jack 1180 × 130mm Galvanised Steel Interlock Garden Edging
- https://www.bunnings.com.au/jack-1180-x-130mm-galvanised-steel-interlock-garden-edging_p3321458
Digging & Preparation
- Shovel
- Mattock
- Wheelbarrow
- Garden rake
- Tape measure
- String line & stakes
- Spirit level
Compaction
Installation
- Rubber mallet
- Screed board (straight timber)
- Trowel
- Angle grinder with masonry blade (for any cuts)
- Broom
- Garden hose
Measured and marked out the project area using string lines before excavating the lawn to the required depth.
- Step 2:
Compacted the existing soil and installed weed mat across the entire area to minimise future weed growth.
- Step 3:
Installed galvanised steel garden edging around the perimeter to create a strong edge restraint and keep the finished project flush with the surrounding lawn.
- Step 4:
Spread and compacted the recycled road base to create a stable foundation.
- Step 5:
Screeded a level bedding layer of paving sand over the compacted base, then carefully laid the charcoal pavers in a diamond pattern, checking levels and spacing as we progressed.
- Step 6:
Filled the gaps between the pavers and the surrounding feature area with decorative pebbles.
- Step 7:
Checked the finished levels to ensure the pavers and pebble areas were flush and free from trip hazards. Cleaned the entire area and made final adjustments to the spacing and levels.
Finally I stepped back and enjoyed a modern, low-maintenance backyard that completely transformed the space!
