Bought an electronic safe from Bunnings and needed it to be ‘safe’
So I built this feature wall in the garage using oak acoustic panels from Bunnings. Added some open shelves with aluminum edging. All from Bunnings. Can you see where the safe is when the wall is closed?
https://share.google/zY2qYp76Gj7DFbcW0
digital safe
https://share.google/lDHNKw9nCatylke5V
https://share.google/7r2OIuOPsYcnPX0RT
https://share.google/cg1kPRUrZln0Bbl00
https://share.google/EtVPpmWNtEOIbpzMg
https://share.google/xD0kGZabktu3ad8W1
https://share.google/JuY5AH8qfuyDLFX62
https://share.google/soSTxtRbgy2hGYqAl
https://share.google/WpwBhvomMrBSoD2uO
stick welder
https://share.google/IPHlXO9bxwyxSzoow
brushless drill, circular saw and angle grinder
https://share.google/gD4FmVNersWrA3Jls
drill bits
Add shelf on top of safe frame and wheels below.
Line walls with oak acoustic panels. Attach to existing wall with liquid nails (10mm spacer underneath) Hint: Measure twice cut once
stand back and admire
Hello @stevep9394
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your garage feature wall project.
What a clever and beautifully executed project! At first glance, it looks like a stunning feature wall that adds warmth and a modern architectural touch to the garage, but there's so much more to it than meets the eye. I was completely fooled by the pull-out table; I was convinced there would be a cleverly concealed push-to-open panel revealing a hidden cabinet! Instead, you've created a multifunctional design that seamlessly combines stylish storage, practical shelving and a brilliantly hidden safe. The oak acoustic panels give the entire wall a premium finish, and the attention to detail makes everything look purpose-built. It's an incredibly smart DIY solution that is as impressive as it is practical. Again, thank you for sharing such a clever project.
