Hated the open shelving in my walk in pantry so decided to create extra bench space for air fryer and coffee machine, food and appliance storage and a wine rack cos, well why not!
Treated pine
https://www.bunnings.com.au/90-x-45mm-outdoor-framing-h3-treated-pine-2-4m_p8032172
Plasterboard
https://www.bunnings.com.au/gyprock-csr-2400-x-1200-x-10mm-2-88sqm-plasterboard-re_p0731415
Kaboodle kitchen cabintry and benchtop with the design help from Sharyn at Bunnings Pakenham
75mm cornice
https://www.bunnings.com.au/gyprock-csr-75mm-x-3600mm-cove-plaster-cornice_p0730647
Tiles
https://www.bunnings.com.au/duratile-10-x-30cm-1-02m-white-gloss-subway-wall-tile-34-carton_p0038766
Stud Adhesive, cornice cement, base coat, top coat, paint, tile adhesive, grout, edge trim, caulk/seal all purchased from bunnings. From start to finish, everything bought from Bunnings!
Hammer, circular saw, drill, impact driver, stanley knife, level, grinder, tape measure, plaster saw, saw horses.
Mitre saw
https://www.bunnings.com.au/ryobi-2000w-254mm-dual-bevel-sliding-mitre-saw_p0087774
Table Saw
Tile cutter hired from bunnings
https://www.bunnings.com.au/for-hire-600mm-hand-tile-cutter-4hr_p5470022
Adhesive trowel
https://www.bunnings.com.au/qep-6mm-square-notch-handyman-adhesive-trowel_p6650391
Cornice mitre box
https://www.bunnings.com.au/builders-edge-55-75-x-90mm-mitre-box_p0730303
Grount float
https://www.bunnings.com.au/qep-4-x-9-economy-grout-float_p0393528
Laser
https://www.bunnings.com.au/dewalt-green-beam-2-way-cross-line-laser_p5660715
Circular saw blade fine cut
https://www.bunnings.com.au/kango-184mm-60t-wood-circular-saw-blade_p0727542
Frame bulk head, install and stop up plaster, demo shelving. Ducted air con return air was in the way of bulk head so had to install a smaller return air grille with the help of my AC guy.
- Step 2:
Paint walls, build and install cabinetry carcuss.
- Step 3:
Cut and install benchtop, cabinet doors and handles, trim around sides or cabinetry, rough in power points and LED strip (I am an electrician)
- Step 4:
Tile splashback, grout tiles, caulk around cabinetry, install cornice, install power points and LED strip light.
- Step 5:
Finishing touches, clean up, touch up paint, paint cornice, install quad on floor around cabinetry, put everything away in cupboards and enjoy!
