This is a human sized chicken coop I made from scratch. I dont have any experience with carpentry or building so I think ive done a great job.
https://www.bunnings.com.au/70-x-35mm-outdoor-framing-h3-treated-pine-2-4m_p8032103?store=5083&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB-BlAtsjAE-38m-CRdaEEo1T&gclid=Cj0KCQjw39zSBhDhARIsANammDs0dmFynYjhdjB8pIWcSgqdK666DCf_hq4mj1TyBmhu5Q8cjQxU9EMaAvrGEALw_wcB
https://www.bunnings.com.au/150-x-12mm-1-8m-h3-ecowood-green-tan-e-paling_p0503483
https://www.bunnings.com.au/suntuf-2-4m-clear-corrugated-polycarbonate-roofing_p1015680
https://www.bunnings.com.au/titan-12g-x-50mm-class-3-galvanised-polydome-roof-screw-200-pack_p0912034
I also used other things like screws, hinges, staples, etc. All from bunnings
Circular saw
Staple gun
Drill
Measured up the area then drew up the plans.
- Step 2:
Flattened the area and dug a moat around for the timber to sit on for water fall.
- Step 3:
Cut the timber to size and started framing. Had some help to connect the sides together.
- Step 4:
Added some timber to one side of the frame to create a fall for the rain.
- Step 5:
Attached the Corrugated sheets to the frame using roofing screws.
- Step 6:
Attached the paling from the bottom to the top to create the effect.
