I knew the vision I wanted, was for a rustic chunky coffee table but these furniture pieces in the shops were beyond my budget. I found the 30kg piece of wood on marketplace which needed some TLC. My level of DIY is low, so it involved several trips to Bunnings. Any excuse for a trip to Bunnings though!
https://www.bunnings.com.au/ryobi-100-x-140mm-10-piece-detail-sanding-set_p0417391
https://www.bunnings.com.au/ryobi-5-piece-belt-sanding-set_p0417439
https://www.bunnings.com.au/taskmaster-400-x-10mm-brushed-brass-steel-hairpin-3-leg_p0226608
https://www.bunnings.com.au/crafted-300ml-gold-project-paint_p0525415
https://www.bunnings.com.au/kids-grip-paint-brushes-4pk_p0859400
https://www.bunnings.com.au/cabot-s-90g-natural-wood-tone-putty_p1523738
https://www.bunnings.com.au/ryobi-800w-76mm-belt-sander_p0873103
https://www.bunnings.com.au/ryobi-18v-one-palm-sander-rps18-tool-only_p0371771
https://www.bunnings.com.au/ryobi-18v-one-drill-driver-starter-kit-r18dd22_p0715241
Using the Ryobi belt sander with a course grit I set to work in removing the indents and tool markings.
- Step 2:
Next I used the Ryobi palm sander, starting with a course grit sander followed by a fine grit to smooth the wood on top and around the edge.
- Step 3:
The wood putty was then used to fill the holes on top.
- Step 4:
I attached the 3 gold legs using timber screws
- Step 5:
I rubbed grape seed oil over the wood which gave the natural look I wanted.
- Step 6:
Finally I used the fine paint brushes and painted the wood filled holes with gold paint.
