Wanted to install an electric wall oven and induction hob. Kitchen was looking old and needed a colour upgrade. Since we extended the dining room a couple of years earlier we had room to extend the kitchen and make better use of the window right side wall cabinet. Using Kaboodle cabinetry, a large corner cabinet was replaced with a blind corner cabinet and oven wall unit. Two extra floor cabinets and two extra wall cabinets were added for the final layout. All existing and new cabinets were repainted "Toad" green for the lower and satin white for the upper cabinets. A new workbench completed the cabinets. A reasonable match for the laminate flooring was sourced from Bunnings. A bit of tiling and under cabinet lights completed the look.
0515716 1 EACH CABINET LEGS KABOODLE++ADJUSTABLE 20 PK W-50666
0175939 18 EACH KITCHEN HANDLE KABOODLE++96MM VELA GOLD W-50477
2662611 1 EACH BASE CABINET KABOODLE++600MM W-51605
2669880 1 EACH PULLOUT BASKET KABOODLE++300MM 3TIER SOFT CLOSE W-
2662006 6 EACH DOOR HINGE KABOODLE++SOFT CLOSE 1PK W-50311
2667718 1 EACH DRAWER RUNNER KABOODLE++SOFT CLOSE 1PK W-50610
2666938 2 EACH DOOR HINGE KABOODLE++SOFT CLSE BLND CNR 1PK W-70932
0253561 1 EACH OVEN TOWER PACK KABOODLE++600MM FIVE SPC MOD W-
0253528 1 EACH BLIND CNR PANTRY PNEL KABOODLE++FIVE SPC MOD W-59140
0253514 1 EACH 1 DRAWER KABOODLE++600MM FIVE SPC MOD W-59130
0253569 1 EACH PANTRY DOOR KABOODLE++600MM FIVE SPC MOD W-59120
0253538 5 EACH CABINET DOOR KABOODLE++300MM FIVE SPC MOD W-59112
0253572 1 EACH PANTRY FILLER PANEL KABOODLE++FIVE SPC MOD W-59141
0253571 3 EACH PANTRY END PANEL KABOODLE++FIVE SPC MOD W-59139
0259492 2 EACH OVERHEAD DOOR CTM KABOODLE++297-399MM FIVE SPC D-59549
0253526 1 EACH BASE FILLER PANEL KABOODLE++FIVE SPC MOD W-59142
0253547 1 EACH KICKBOARD KABOODLE++2400MM FIVE SPC MOD W-59151
0255218 1 EACH DEEP OVERHEAD CAB CTM KABOODLE++600-699MM D-81055
0253555 1 EACH MICROWAVE BOX KABOODLE++600MM FIVE SPC MOD W-59148
2662248 1 EACH 1 DRAWER BASE CABINET KABOODLE++600MM W-51611 193.04
2662259 2 EACH WALL CABINET KABOODLE++300MM W-51621
2662597 1 EACH BASE CABINET KABOODLE++300MM W-51602
2667660 1 EACH BLIND CORNER PANTRY KABOODLE++2055X1000X580 CAB W-70116
Wall Oven (and grill) (Westinghouse)
Cooktop (Westinghouse)
Electrical Instal
Floor boards
sandpaper
Paint - Dulux renovation range
-primer
- White satin top coat
- Green (Toad) satin top coat
roller covers
Tarps
Measuring cups
Duct tape1
Hooks
Tradesman Stan the stand cabinet levelling system
Workbench
Tiles
Kitchen before renovation.
- Step 2:
All doors and panel removed for painting. Note: existing cabinets mounted on a wooden frame, which will be replaced by adjustable feet.
- Step 3:
Paint existing panels and doors.
- Step 4:
Delivery of new cabinets, doors and panels ready for painting
- Step 5:
Re-installed all painted doors, drawer covers and panels. Replace the cabinet mounts with adjustable feet. Repair/replace laminate flooring. Install new cabinet to extend kitchen and workbench.
- Step 6:
Remove existing cornet cabinet, move pan drawers over to where the gas stove was. Repair/replace laminate flooring. Install painted new blind corner pantry and small slide out basket cabinet.
- Step 7:
Install wall oven cabinet, ready for oven/grill installation. Install two new wall cabinets either side of relocated hood exhaust cabinets. Install all new and painted doors and panels. Note; the use of portable cooking elements.
- Step 8:
Wall oven/grill and induction hob installed. Tiling complete into hood exhaust area. Temporary bits of board used to patch up workbench. New workbench measured and ordered.
- Step 9:
Workbench installed. (and under cabinet lighting)
- Step 10:
Finished.
