Transformed a very basic three tier lozenge book shelf, which had simply become everyone’s dumping ground, in to a bespoke closed-door slimline hallway console.
Before:
After:
Flexible fluted wood panels
Curved handles:
https://www.bunnings.com.au/prestige-16mm-brushed-nickel-wave-pull-handle_p3962348
MDF board for doors:
Sample pot of paint
Selleys Caulking & Fast Grab Liquid Nails
https://www.bunnings.com.au/selleys-420g-liquid-nails-fast-grab-strong-adhesive_p1230096
No more Gaps
https://www.bunnings.com.au/selleys-475g-no-more-gaps-interior-multipurpose-gap-filler_p1230010
Sanding blocks
https://www.bunnings.com.au/rocket-fine-sanding-sponge-fine_p1661077
Ryobi One+ tools
- circular saw
- drill
- multi tool sanding pad
Using the circular saw, cut down the dedth of the lozenge into a more slimline profile. Turning the fully rounded edge in to a semi-rounded shape. Reattached the vertical legs for stability.
- Step 2:
Using Liquid Nails as the adhesive, wrap the fluted wood panels around the sides of the unit, and over the MDF board. Cut the MDF board down to the right size to create doors. Attach hinges to the doors and secure to the body of the unit.
- Step 3:
Sand down all area that will be painted - using multitool sanding pad and the manual block. Paint the unit with two coats and allow to dry in between. Attach the handle and style.
