Hi
Could you please provide some guidance on how to repair the dining chairs that have torn leather upholstery?
Thanks.
Hi @AJ-DIYer
Ok so there are specialist leather repairers out there and not knowing where you are means I can't suggest a local company. I had a car with leather upholstrey that I was selling which had damage and I called in one of these and when they had finished, you couldn't tell it had ever been damaged!
@AJ-DIYer
Just a note here. This is not something I would recommend you DIY as it is a specialized job.
Hi @AJ-DIYer,
I'm in agreeance with @R4addZ that major leather upholstery repair is not really within the realm of D.I.Y.
If tears are small and don't justify contacting a professional, then an adhesive like this https://www.bunnings.com.au/selleys-50ml-kwik-grip-crystal-clear-contact-adhesive_p1230163 could potentially be used, but that is assuming that the leather has just ripped, and nothing has shrunk, moved or been removed.
There are also options for chair covers available through our Marketplace sellers, although they would not cover the bottom of the extended back on your chairs. This https://www.bunnings.com.au/artiss-dining-chair-slipcovers-4-pack-spandex-stretch-banquet-wedding-white_p0637362?srsltid=AfmBOooc-cDBrxTI6askmrz1Y-wuqNTDJQCYDlOp5VZg7D4SzJGF_r9lzfQ is one example.
Beyond this, it would be best to contact a professional leather repairer or an upholsterer. They may be able to repair the leather or reupholster them for you.
