I built my partners dream gaming desk into the nook in our lounge room. I built this in as a permanent fixture, complete redesigning the space.
140 x 19mm 3.0m DAR Pine Standard & Better
https://www.bunnings.com.au/applinks_p8400038?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
Govee RGBIC+W Strip Light S 5m
https://www.bunnings.com.au/applinks_p0829723?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
Framing timber fixed around the wall and under desk as extra support
Zenith 10G x 50mm Gold Passivated Type 17 Countersunk Head Timber Screws - 50 Pack
https://www.bunnings.com.au/applinks_p2409143?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
British Paints Black Matt Clean And Protect Interior Paint - 2L
https://www.bunnings.com.au/applinks_p0561931?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
paint brush, paint tray and roller (I’ve had these products so long I couldn’t tell you what they were but I know I got them at Bunnings)
Masking tape
Hole filling paste
drill
Bit driver
Timber drill bits
Saw
Hammer
Sand paper
Paint scraper
Measuring tape and straight edge, ruler or square
1- measured the space, planed design, selected the products I needed using the Bunnings app, picked up everything I needed to get started
2- cleared out the space, cleaned the walls with sugar soap, filled in all holes and sanded before painting
3- masked all edges, cut in with paint in all corners, edges and between slats. Pained 2 coats of paint, allowing enough drying time between coats.
4- cut to length, pre drilled holes and fixed timber frame to walls
5- cut boards to length, in the first board against the wall, cut semicircle to allow for screen mounting and cable pass through. Fixed into place. Cut all boards to length and fit into place.
6- used same timber as framing to fix to the bottom of the desk top to create support and prevent movement to create flat desk surface
7- cleaned up work area
8- set up gaming pc and screens, hung lights and signs.
