Hi I'm building a timber fence what is a good budget battery Nail gun that will do the job please.
Hi @galey,
Unfortunately, there isn't really a budget battery nail gun that is suitable for this type of work. Most battery nail guns on the cheaper end are either framing nailers or brad nailers. A framing nailer fires heavy structural nails which if used would split the palings, and a brad nailer fires very small finish nails which would not have the holding capacity you need.
Fencers typically use coil nailers for installing palings. They fire ring shank coil nails, which are the only nails I would recommend for attaching timber palings. The only battery powered coil nailer that I am aware of is the https://www.bunnings.com.au/paslode-impulse-coilmaster-27-50mm_p0624588 , which is not exactly a budget option.
Most fencers will use a pneumatic coil nailer, which needs to be attached to an air compressor. If you were happy to go with this option, the https://www.bunnings.com.au/ryobi-airwave-coil-nailer-ra-nc1565-k-tool-only_p6210572 alongside a https://www.bunnings.com.au/ryobi-airwave-50l-2-0hp-air-compressor-ra-c2550-g_p6210594 comes in at a reasonable price.
You can also hire this https://www.bunnings.com.au/for-hire-air-coil-nailer-24hr_p5470103 alongside a https://www.bunnings.com.au/for-hire-air-compressor-24hr_p5470065 to attach your palings once you are at that stage of the job. If you are set on using a coil nailer, this is likely the most economical option.
Alternatively, using screws to attach your palings is often a better choice if you aren't planning to do a lot of fencing in the future as you can simply use a drill, impact driver or combination of the two. These tools are much more varied in their applications and much more practical to own if you are not employed in the construction industry. It will be a bit slower than using a coil nailer, but in all honesty, I have never met someone who isn't a builder or fencer for a living that really needs to own a coil nailer.
You might like to check out our series on https://www.bunnings.com.au/diy-advice/building-construction/fences-gates/how-to-build-a-fence for some further guidance.
Thank You Jacob, some great advice.
I'll either hire or go the screw option.
Cheers
Paul
