This custom letterbox and house number display entirely was DIY project. From constructing the blockwork structure to installing the letterbox and creating the large “65” house number, every step was a DIY project. The bold, modern design makes the house number highly visible while giving the front of the home a unique and durable finish. It was a rewarding project that combined practical building skills with creativity, resulting in a functional and eye-catching entrance feature.
https://www.bunnings.com.au/pgh-common-brick-vic-only-230x110x76mm_p0078201
https://www.bunnings.com.au/trojan-280mm-lightweight-plasterers-float_p0551215
https://www.bunnings.com.au/bastion-20kg-mortar-mix_p0038286
https://www.bunnings.com.au/holman-32mm-90-white-pvc-elbow_p3141320
https://www.bunnings.com.au/craftright-280mm-plastering-trowel_p0924474
https://www.bunnings.com.au/ryobi-10-piece-masonry-drill-bit-set_p0354578
https://www.bunnings.com.au/dulux-avista-oxide-1kg-white-cement-colouring_p0760496
https://www.bunnings.com.au/click-5m-white-extension-lead_p0189130
https://www.bunnings.com.au/kango-masonry-drill-bit-10-piece-set_p0727597
https://www.bunnings.com.au/davco-20kg-off-white-render_p0034887
https://www.bunnings.com.au/selleys-475g-no-more-gaps-interior-multipurpose-gap-filler_p1230010
https://www.bunnings.com.au/parfix-340g-expanding-foam-filler_p1232844
https://www.bunnings.com.au/poly-750g-expanding-foam-aerosol-can_p1230034
https://www.bunnings.com.au/trojan-115m-brick-bolster_p0551210
https://www.bunnings.com.au/metal-mate-20-x-1-6mm-1m-silver-aluminium-flat-bar-silver-1m_p1064257
https://www.bunnings.com.au/uni-pro-230mm-medium-foam-texture-roller-cover_p1660574
https://www.bunnings.com.au/siniat-30-x-3000mm-90-pvc-external-angle-plaster-trim_p1090756
https://www.bunnings.com.au/dulux-10l-texture-full-cover-exterior-paint_p1371216
https://www.bunnings.com.au/paint-partner-270mm-roller-tray_p0794475
https://www.bunnings.com.au/bastion-1200-x-600-x-30mm-xps-multi-use-foam-board_p0461085
https://www.bunnings.com.au/ryobi-18v-one-hammer-drill-all-rounder-kit-r18pd24_p0539759
https://www.bunnings.com.au/holman-90mm-storm-abs-finish-collar-with-grate_p4770338
https://www.bunnings.com.au/stanley-3-piece-wood-chisel-set_p0336698
- Created the house number 65 using a mould and prepared it for installation.
- Constructed a formwork (box) and poured concrete to cast the house number.
- Allowed the concrete to cure completely before removing it from the mould and preparing it for outdoor installation.
- Built the letterbox post by laying bricks with mortar to the required height and dimensions.
- Formed the brick structure to fit the letterbox and securely positioned the letterbox within the post.
- Installed the concrete house number 65, ensuring it was firmly bonded and correctly aligned with the brickwork.
- Verified that the letterbox, brickwork, and house number were level, plumb, and securely fixed.
- Installed the Rondo 2400mm 90° External Corner Bead on all external corners before rendering.
- Applied the render evenly over the brickwork, allowed it to partially set, and completed the finishing to achieve a smooth, consistent surface.
- Allowed the rendered letterbox to cure for 1–2 days, then applied Dulux 10L Texture Full Cover Exterior Paint to complete the project.
