I found this 1940's Chillerator fridge in bad condition, totally termite eaten. I totally restored it right down to matching the original colour.
Pine wood for frame, Plywood sheet, brad nails, wood glue, screws, sandpaper, paint.
Circular saw, router, sander, sanding block, sand paper, brad nailer, drill, paint spray gun, welder, soldering iron, kero burner torch
- Take full measurements of everything including exact positions of catches, hinges, nameplate on the door.
- Strip the whole thing down and separate the internal metal cabinetry inside.
- Clean and cover the internal metal cabinetry.
- Source correct sized pine to recreate the frame.
- Cut each frame section and recreate the exact radius's used on each frame section.
- Set up dowels for each joint
- Assemble, glue, strap, and clamp the new frame together.
- Cut the plywood doors, sides, top and bottom.
- Rout radius everything that needed it.
- Sand everything smooth.
- Primer paint the frame and plywood panels.
- Solder repair a section of the top icebox compartment drip tray.
- Assemble everything and top coat paint the fridge
- Get hinges and catches re-chromed and rebuilt.
- Install the internal metal cabinetry.
- Lay out, mark and pre-drill holes for catches, hinges, nameplate badge, then fit them.
- Install new door seals
- Weld repair the base legs and feet then paint.
- Finished.
