living with 6 teenagers means you need to stock the house with copious amounts of food… when your pantry is not big enough to accommodate said food and you need more storage, you make an additional pantry using nothing but Bunnings products!
https://www.bunnings.com.au/flexi-storage-home-solutions-1225mm-white-advanced-storage-double-slot-front-wire-shelf-a-_p2660976
https://www.bunnings.com.au/flexi-storage-home-solutions-350mm-white-advanced-storage-double-slot-wire-shelf-bracket_p2660965
https://www.bunnings.com.au/flexi-storage-home-solutions-2133mm-white-advanced-storage-double-slot-wall-strip_p2660946
https://www.bunnings.com.au/adoored-75mm-medium-stain-timber-bullet-door-stop_p0349171
https://www.bunnings.com.au/kaboodle-96mm-jardin-matt-black-handle_p0419845
https://www.bunnings.com.au/austyle-100-x-47-x-2-5mm-black-stainless-steel-fast-fix-non-mortise-flush-hinge_p0119736
https://www.bunnings.com.au/wiz-motion-and-daylight-sensor-smart-accessory_p0331091
https://www.bunnings.com.au/ryobi-18v-one-hammer-drill-all-rounder-kit-r18pd24_p0539759
https://www.bunnings.com.au/kango-1200mm-wrecking-bar_p0553620
https://www.bunnings.com.au/ryobi-18v-one-caulking-gun-tool-only_p0385366
https://www.bunnings.com.au/paint-partner-mini-roller-kit-10-piece_p0328966
Clean out junk from cupboard. clean and sugar soap walls.
Prep wall with spacfiller, stain blocker & paint.
measure and mark where you want your flexi home storage rails to go. Be sure to measure the distance between each shelf.
Clip in your FlexiHome shelves.
Add your door stops and hinges to the door frame, to ensure a smooth finish and alignment of your doors. Add motion sensor light to the new pantry for ease of viewing.
Fill pantry with food.
Enjoy your new space.
Hello @jskntlow
Welcome to the Bunnings workshop community. It's sensational to have you join us, and thanks for sharing your overflow pantry project.
This is such a smart solution for a busy family, and it looks like it has always been part of the home. Transforming an underused cupboard into a bright, organised overflow pantry is a fantastic way to maximise storage, and the adjustable shelving makes it practical for everything from everyday groceries to bulk supplies. The fresh finish, tidy layout and timber doors blend beautifully with the surrounding space, creating a pantry that's both functional and stylish for family life.
Again, thank you for sharing such a clever project.
