Hi there
I am enclosing our deck to become a part of our interior home, a second living area. The deck is about 35 square meters. We are going to put in Floor Select waterproof hybrid flooring. I am planning to put 15mm h3 plywood as a subfloor on top of the existing h3 pine deck which has 6mm gaps in the planks. There is about 1metre under the deck, it is well ventilated but does get wet ground and some moisture under the planks during rain as we are on a bit of a slope. I wondered if I should use builders film between the h3 pine deck and the plywood to protect the ply? I also wondered if I should use builders film between the plywood and the hybrid flooring to stop moisture rising into the Hybrid built in foam underlay and also as foam underlay can stick to plywood? Also any other advice? There is mixed advice online in articles and forums with some saying to use film at one or the other stage, others saying at no stage.
Thanks in advance,
Mark
