As a family who loves staying active our collection of bikes, skis and outdoor gear quickly turned our front entrance into an equipment overload. We wanted a practical storage solution that kept everything organised, easy to access and looked great from the moment you walked through the door. After giving the wall an updated paint, using Tasmanian oak, stain and hardware from Bunnings we designed and built a custom wall-mounted storage system. Every piece was measured, stained and securely fixed into the wall, transforming a cluttered entry into a functional, welcoming space that showcases our family's passion for adventure.
https://www.bunnings.com.au/65-x-12mm-2-4m-dar-tasmanian-oak-select_p0070238
https://www.bunnings.com.au/cabot-s-250ml-walnut-interior-stain_p1521841
https://www.bunnings.com.au/uni-pro-63mm-you-can-do-it-synthetic-wall-paint-brush_p1660499
https://www.bunnings.com.au/uni-pro-100mm-little-ripper-jumbo-fabric-roller-cover-and-frame-set-10mm-nap_p1661826
Interior Wall Paint
https://www.bunnings.com.au/carinya-190-x-140mm-rustic-timber-angle-bracket_p0923978
https://www.bunnings.com.au/zenith-8g-x-40mm-countersunk-rib-head-chipboard-screws-100-pack_p2408430
https://www.bunnings.com.au/everhang-28mm-black-cup-hook-10-pack_p0086514
https://www.bunnings.com.au/macsim-42mm-plastermate-zinc-anchor-12-pack_p0057448
https://www.bunnings.com.au/adoored-black-dene-deco-hook_p3962188
Measuring tape
Pencil
Spirit Level
Impact Driver
Drill
Ladder
Purchased all timber, hooks, screws, wall anchors, stain and supplies from Bunnings.
- Step 2:
Stained Tas Oak to match hooks, allowing them to dry before installation.
- Step 3:
Measured the wall and marked out the position and spacing of each ski rack using a mock-up to ensure comfortable clearance.
- Step 4:
Pre-drilled all holes in the timber, then marked and drilled the wall for the mounting points.
- Step 5:
Installed plasterboard anchors where required and securely fixed the timber uprights and ski hooks to the wall.
- Step 6:
Measured the bicycle storage area, double-checking spacing to allow easy access and prevent the bikes from touching.
- Step 7:
Pre-drilled the timber and wall for the bike racks, then installed wall anchors and securely fixed each bike mount.
- Step 8:
Mounted the bikes, skis and accessories, making final adjustments to ensure everything is organised and easy to access.
- Step 9:
Installed the coat hooks for jackets.
