Any suggestions as to the best product to use to fill this trench-like gap in a window sill? I won't bore you with the details of how it came to be, but it was routed out (badly). As far as I can tell the material is mdf. I'm going to first place a gap filler rod into it and then i need a filler that will harden, can be sanded and painted and that won't shrink. The trench is around 1.6m long, 20mm wide & 10mm deep (before putting in the filler rod). Would greatly appreciate advice on the best product to use. Thanks in advance.
