best way to add a mount plate/bracket for an EV charger to be attached to carport post?
Hi @ks1973
Do you already have the plate and/or the charger? If so, any chance of pictures?
it will be the Tesla wall charger. Looking for any suggestions of how to mount a back plate? Thanks
Hello @ks1973
Thank you for sharing your question about installing your EV mounting plate. It's a good idea to start by checking the installation instructions for your specific EV charger. Many manufacturers specify who should carry out the installation, and some require the entire installation process, including mounting the charger, to be completed by a licensed electrician to meet warranty and compliance requirements.
If you're only considering installing a backing plate or mounting bracket, first confirm that the manufacturer allows this to be done separately. It can also be worth speaking with the electrician who will be installing the charger, as they may prefer to supply and fit the mounting plate themselves to ensure it is positioned correctly, provides adequate support, and suits the planned cable entry and electrical installation.
Keeping safety in mind is always the best approach. If there is any uncertainty about the manufacturer's requirements or your local electrical regulations, leave the work to a licensed electrician. This helps ensure the installation is safe, compliant, and covered by the manufacturer's warranty.
@ks1973
Is there a specific reason you want to mount this on a plate as the manual shows two centrally located screws, one top and one bottom. so if you mount a plate and try to keep everything central, the screws will go through the plate and then try to go through the post!
Might I suggest something like this….
Enclosure
It would keep things more secure and increase the life of the charger.
