Renovating house in regional victoria - so extreme variances to temperature…
I have noticed as I renovate, various things in this old 50 year old structure - how building techniques / products have changed.
So it has corrugated roofing - as far as I can tell - no leaks. I know this was replaced around 20 years ago and it still looks good. Its flat roof at around 10 degrees. Skillon type roof - and there is no cavity….
In the back room, I have taken down the old masonite ceillings and walls, found insulation in the ceiling - old / musty… Always intended to replace this and to actually plaster it.
My concern is condensation. As I have no ceiling / no insulation currently - and there is no sarking I can see easily a lot of condensation. Concerned if I just plaster up things with some insulation - I am just hiding an issue.
I dont have the option to remove the sheets of roofing material - they are some 30m long and will be too big of a job.
So what can I do ? Retrofitting…. ChatGPT contradicts Claude - great AI war in my mind…
Because I cannot guarantee airflow - the picture shows the battens do not sit on top of the eaves - they are cut into the eaves… Meaning the eaves and battens are actually the same height (damn it!) This further restricts the airflow…
ChatGPT is suggesting I cannot let any insulation material touch the roofing… as condesnation will still occur and rot / mould that insulation. Claude suggests cutting to fit Anticon-style blanket insulation pushing hard up against the roofing material and then to add as much insulation batts as possible to fill the space.
Quite contradictery really? I know I cant make it perfect - just as long as I am not introducing mould on to the plasterboard is probably the best I can achieve…
Any advice ?
