My partner and I upgraded the front door entrance which was previously a painted concrete slab and a yellow front door. We applied all Bunnings products to create a mediterranean style crazy paved tile look, adding planter boxes along the side and painting the front door. This project took roughly two weeks for the whole lot. Can you tell we recently got back from europe? Thank you for considering us! Please help us to fund the next crazy pave project in the backyard in our newly purchase home which has 100x upcoming DIY projects. Thank you!!
Materials (all purchased from Bunnings)
Crazy Pave Steps
https://www.bunnings.com.au/decor8-tiles-300-x-300-x-10mm-beige-java-marble-tile-mosaic_p6661037?store=6427&gclsrc=aw.ds&gad_source=1&gad_campaignid=21112196286&gbraid=0AAAAADtbEB-wZUSSAVDSyz9MZpVZ2FvYQ&gclid=Cj0KCQjw6_HSBhCpARIsANvVlta71GinkNAlE5MH7AS-G9LhtwQTA1rKkGO_j_C_qo9fyAMpTaUI-y0aAhyqEALw_wcB x50
https://www.bunnings.com.au/bastion-wet-area-primer-1l_p0612563?store=6427&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB-iWQn1U_w-exxIiDtuIpJ1C&gclid=Cj0KCQjw6_HSBhCpARIsANvVltYC6omm-bXgzvJfGNCf_jn8fbLSkDsTB51bqQu-UIoe5tt_NphQ6lEaApIzEALw_wcB x1
https://www.bunnings.com.au/dunlop-20kg-white-super-tileset-plus-tile-adhesive_p0205085?region_id=116427&gclsrc=aw.ds&gad_source=1&gad_campaignid=21112196286&gbraid=0AAAAADtbEB-wZUSSAVDSyz9MZpVZ2FvYQ&gclid=Cj0KCQjw6_HSBhCpARIsANvVlta3lAuwDSiaCWd9l77q9NKUf-Vbb8dLnYyS8y4-AP-CyEWgMTUjJpkaAnJcEALw_wcB Dunlop 20kg White Super Tileset Plus Tile Adhesive x1
https://www.bunnings.com.au/davco-15kg-49-light-grey-sanitized-colourgrout_p6650022?store=6427&gclsrc=aw.ds&gad_source=1&gad_campaignid=21112196286&gbraid=0AAAAADtbEB-wZUSSAVDSyz9MZpVZ2FvYQ&gclid=Cj0KCQjw6_HSBhCpARIsANvVltYMwAXdh8_ZBWGUSQZxmNm8ekb-S1A94GTzlkKcegUAfP-Jta6f2CsaAo5PEALw_wcB x1
https://www.bunnings.com.au/crommelin-1l-natural-finish-penetrating-sealer-and-water-repellent_p0356894 x1
https://www.bunnings.com.au/oates-long-handle-deck-scrub-brush_p4460246?region_id=116427&gclsrc=aw.ds&gad_source=1&gad_campaignid=20876642384&gbraid=0AAAAADtbEB_uQMMijTuBHO91UcFZsGU8x&gclid=Cj0KCQjw6_HSBhCpARIsANvVltaWt9AMnMWaXXrVnwZkIaRTNgxMTl-LrazrdbPY6vSIRvHQbzDSiRoaAgycEALw_wcB Oates Long Handle Deck Scrub Brush x1
https://www.bunnings.com.au/dta-tilers-n-slaters-hydro-sponge_p6823860?store=6427&gclsrc=aw.ds&gad_source=1&gad_campaignid=21112196286&gbraid=0AAAAADtbEB-wZUSSAVDSyz9MZpVZ2FvYQ&gclid=Cj0KCQjw6_HSBhCpARIsANvVltb8uuXj_H8si935dUu316WVPVhFoi4yaD7mw7eudmc2ryGOxFcqNakaAibgEALw_wcB x2
https://www.bunnings.com.au/handy-pail-20l-round-pail_p0909257 x2
https://www.bunnings.com.au/ezitile-adhesive-grout-mixing-paddle_p0592160?store=6427&gclsrc=aw.ds&gad_source=1&gad_campaignid=21112196286&gbraid=0AAAAADtbEB-wZUSSAVDSyz9MZpVZ2FvYQ&gclid=Cj0KCQjw6_HSBhCpARIsANvVltaJHzgyIqAsSW1jisH69CcqkLKK-MPMaObRarN5MF7V0RxHuo1nd9AaAo1vEALw_wcB x1
Paint Front Door
https://www.bunnings.com.au/british-paints-4-seasons-extra-bright-low-sheen-exterior-paint-4l_p0207100 x1
https://www.bunnings.com.au/dulux-4l-precision-white-maximum-strength-adhesion-primer-4l_p1400849?region_id=116427&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB9Fr0r1qJyi0dExT-m5vc5_H&gclid=Cj0KCQjw6_HSBhCpARIsANvVlta5JtMlI-Fswar6oacN1m8vOhkpCCukYojqxpZtYl3MxF0dRtQqjLIaAn4bEALw_wcB Dulux 4L PRECISION White Maximum Strength Adhesion Primer - 4L x1
https://www.bunnings.com.au/uni-pro-100mm-4mm-nap-little-ripper-microfibre-mini-roller-set_p0022470
Planter Boxes
https://www.bunnings.com.au/northcote-pottery-80cm-white-terrazzo-look-precinct-lite-trough_p2831987 x3
https://www.bunnings.com.au/scotts-osmocote-50l-premium-potting-mix_p2962143 x3
https://www.bunnings.com.au/brunnings-5l-perlite_p3010203 x6
https://www.bunnings.com.au/125mm-dichondra-shade-sensations-range_p0184417 x6
https://www.bunnings.com.au/200mm-white-bird-of-paradise-strelitzia-nicolai_p0353508 x3
https://www.bunnings.com.au/ryobi-18v-one-drill-driver-starter-kit-r18dd22_p0715241
https://www.bunnings.com.au/ryobi-18v-one-125mm-random-orbital-sander-tool-only_p0371770?srsltid=AfmBOord2Hw6mCRWktxp00asLKs1KrUCf3VhpaM0eKROEguL0FjcSOzkZJ4
STEP 2: Use the angle grinder with a safety goggles and mask to roughen the surface of the step to allow to products to adhere and last
STEP 3: Wash the step again and allow to dry (24h) AND apply the primer (allow primer 30min to dry)
STEP 4: Mix the glue. Start laying the edge tiles around the perimeter.
STEP 5: Lay full sheets of the tiles and use the filler pieces to fill the gaps until the whole step is covered. Allow the tiles to set for ideally at least 24 hours before grouting (if the tiles aren’t set, they will slide when applying grout, we learnt this the hard way)
STEP 6. Apply the grout once step 5 is fully dry.
STEP 7: Allow the grout to fully dry (can be several days) until applying the sealer per instructions. We used an empty windex bottle, poured the sealer in then sprayed it (some people use a paint roller)
STEP 8: FRONT DOOR (CLEAN > SAND > CLEAN > PAINT TAPE > PRIMER > TOP COAT X2)
STEP 9: MIX SOIL AND PERLITE IN THE PLANTER BOXES
Hello @DIY_
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your mediterranean front entrance project.
This front entrance has been transformed into a bright, elegant space with a beautiful Mediterranean feel. The crazy paving creates a timeless feature, while the fresh front door and carefully chosen planters add warmth and character that make the entrance feel so welcoming. It's easy to see the European inspiration shining through, and the attention to detail has created a stylish first impression that really elevates the whole home. Best of luck with the next crazy paving project, it will be exciting to see what you create next!
Again, thank you for sharing such a wonderful project.
