The KOOKABURRA door!!!…. Was a must have.
After purchasing my first property, myself (train driver 29) and my dad (garbo 57) decided between the two of us and some help from family and friends and our local BUNNINGS (Epping).
We could really do the place up nice. We have repainted the house and kitchen cabinets, extended the veranda, added a deck and new range hood, built a work bench and shed, cut down trees, added fence extensions, laundry cupboards, doggy doors, replaced doors and handles, light fittings and outlet caps, all with materials from BUNNINGS.
NOW ITS ONTO THE FENCE!!
https://www.bunnings.com.au/daytek-6-line-anthracite-black-retractable-clothesline_p0135245
https://www.bunnings.com.au/hume-2040-x-820-x-35mm-entrance-door-duracote-glass-opening-g1-glass-xf3_p1970270
https://www.bunnings.com.au/corinthian-2040-x-820-x-40mm-entrance-door-windsor-bevelled-kookaburra-glass-win7g_p1969271
https://www.bunnings.com.au/practa-180-x-150cm-25mm-white-aluminium-venetian-blind_p0513576
https://www.bunnings.com.au/gainsborough-bright-gold-traditional-trilock-lever-set_p4180961
https://www.bunnings.com.au/ikonic-brushed-nickel-ruby-privacy-knob-set_p0755208
https://www.bunnings.com.au/kaboodle-96mm-antique-bow-handle-brushed-bronze_p2662576
https://www.bunnings.com.au/pinnacle-90mm-single-loose-pin-radius-butt-hinge_p0074236
https://www.bunnings.com.au/hafele-105-full-overlay-soft-close-clip-on-hinge-10-pack_p0037940
https://www.bunnings.com.au/click-8w-90mm-cct-led-downlight_p0516233
https://www.bunnings.com.au/brilliant-15cm-timber-and-smoked-glass-marais-batten-fix-shade_p0447456
https://www.bunnings.com.au/selleys-130g-no-more-gaps-bathroom-and-kitchen-gap-filler_p0281572
https://www.bunnings.com.au/dulux-2l-renovation-range-cabinet-doors-satin-white_p0116477
https://www.bunnings.com.au/monarch-100mm-4mm-nap-doors-trims-and-cupboards-mini-rollers-5-pack_p0631969
https://www.bunnings.com.au/monarch-270mm-comfort-grip-roller-frame_p1560517
https://www.bunnings.com.au/irwin-300mm-quick-grip-mini-clamp-2-pack_p0215574
https://www.bunnings.com.au/irwin-3-piece-vise-grip-plier-set_p0362838
https://www.bunnings.com.au/ryobi-stud-finder-with-ac-detection-rysf5003_p0374422
https://www.bunnings.com.au/trojan-300mm-tubular-hack-saw_p0191085
https://www.bunnings.com.au/ryobi-airwave-c1-series-air-brad-nailer-ra-nb1832-s_p6210563
https://www.bunnings.com.au/ryobi-240w-1-4-sheet-sander-rss240q-s_p6210544
https://www.bunnings.com.au/ryobi-airwave-3-in-1-air-brad-nailer-and-stapler_p6210571
https://www.bunnings.com.au/ryobi-airwave-clipped-head-air-framing-nailer_p6210568
https://www.bunnings.com.au/ryobi-airwave-inflator-air-tool-kit_p0286893
https://www.bunnings.com.au/ryobi-18v-one-115mm-angle-grinder-tool-only_p0509295
https://www.bunnings.com.au/ryobi-2000w-254mm-dual-bevel-sliding-mitre-saw_p0087774
https://www.bunnings.com.au/ryobi-18v-one-hp-brushless-jigsaw-tool-only_p0291678
https://www.bunnings.com.au/ryobi-one-18v-55cm-hp-brushless-cordless-hedge-trimmer-tool-only_p0340646
https://www.bunnings.com.au/ryobi-18v-one-hp-brushless-184mm-circular-saw-tool-only_p0671490
https://www.bunnings.com.au/ryobi-18v-one-hp-brushless-reciprocating-saw-tool-only_p0671488
https://www.bunnings.com.au/victa-25-4cc-petrol-2-stroke-straight-shaft-trimmer_p0851274
https://www.bunnings.com.au/victa-16-40cc-2-stroke-petrol-chainsaw-with-oregon-bar-and-chain_p0493753
https://www.bunnings.com.au/victa-25-4cc-petrol-2-stroke-blower-vac_p0923310
To redo the kitchen all cabinet doors had to be taken off and sanded back and patched up. Before using Dulux renovation range cabinet doors with 4mm roller which took about 5 coats then finished with a clear coat and new handles
- Step 2:
Extending the veranda and adding decking. Involved taking out the old posts and replacing them with a solid beam across to support the extension.
The decking included building the frame with waterproofing tar then adding merbau decking and using Cabot’s deck stain for finish
- Step 3:
These are some progress shots of all the other projects undertaken
