Picked up a basic metal side table off marketplace for $10, and wanted to give it a bespoke feel for our home with a crazy pave feature.
Before:
After:
Stone path 4pack floor tiles:
https://www.bunnings.com.au/tuscan-path-4-piece-click-floor-tiles_p0874783?store=2052&gclsrc=aw.ds&gad_source=1&gad_campaignid=23022021534&gbraid=0AAAAADtbEB-cUwuFnKDoApEGg9qECv-XJ&gclid=Cj0KCQjw6_HSBhCpARIsANvVltYDFZnLJhWUhv9aLfY8wXSqsV7mazBGxelrrvOoWGjUIuBNV1mgZvwaAp9nEALw_wcB
Adhesive:
https://www.bunnings.com.au/dunlop-4kg-premixed-resaflex_p6829395
Ready to go grout:
https://www.bunnings.com.au/dunlop-800g-white-ready-to-go-coloured-grout_p6650123
Gloves
Dense sponge
Bucket of water
Notched adhesive trowel
Rubber pointed grout trowel
Using protective gloves, remove the plastic click together backing on the floor tiles. Pull the individual stones from the mesh backing.
- Step 2:
Lay the stone pavers down on the inside of the metal table top, in a random / organic pattern, unlike traditional mosaic. Make sure the stones are as close together as possible. Once you’re happy with the placement, take a picture for reference.
NOTE: if the surface is completely smooth, you may need to sand down the surface first.
- Step 3:
Remove 1/4 of the stones at a time, and lay down your adhesive on the metal surface using a notched trowel. I used some leftover Resaflex tile adhesive, which was the ideal choice for my project given the movement of the metal surface.
- Step 4:
Add grout to fill the gaps, following the instructions for application. Using a damp sponge or cloth to wipe up excess after 5-10mins and let the grout cure overnight. Add a clear matt/gloss sealant or vanish dependant on whether it’s for indoor or outdoor use.
