I decided to build this completely from scratch because every commercial coop I looked at was way too small, flimsy, and made it impossible to actually maintain properly. I wanted something built to last a lifetime, so I built it myself.I built a housing coop integrated into a massive 1.5m x 1.8m with a total run length of 4.5m. The design allows me to fully walk right into the enclosure, but the real highlight is the custom drop-down side access panel I built into the housing unit. This lets me easily sweep out and clean the entire interior from the outside without any awkward bending. I clad the exterior in precision-lapped Weathertex weatherboards for a clean, modern aesthetic, and lined the floor with heavy-duty Formply so wiping it down is a breeze. I put real pride into every single stud, joint, and fastener to ensure a safe, draft-free, and completely predator-proof home.
0616146 | H4 70x45mm 3.9M Treated Timber – Qty: 4
8032130 | H3 70x45mm 3.6M Treated Pine – Qty: 36
0020735 | H3 138x18mm 5.4M Primed Pine DAR – Qty: 2
0340319 | 17mm Film Face Plywood (2400x1200mm) – Qty: 2
0021243 | H3 42x18mm 5.4M Primed Pine Trim – Qty: 1
0497557 | H3 30x11mm 2.7M Pine DAR – Qty: 4
0020838 | H3 31x31mm 5.4M Primed Pine External Angle – Qty: 1
0340315 | 12mm Ecoply Plywood (2400x1200mm) – Qty: 1
0240399 | Weathertex Classic Ruff Sawn Weatherboards (3660x200mm) – Qty: 16
3040084 | Aviary Wire Mesh (120cm x 5M) – Qty: 5
2420887 | Zenith 10x75mm Timber Screws (500 Box) – Qty: 1
2420877 | Zenith 8x50mm Timber Screws (500 Box) – Qty: 1
0080652 | Pinnacle 150x10mm Padbolts – Qty: 3
0094743 | Pinnacle 90mm Black Hasp & Staple – Qty: 1
2410091 | Zenith 8-15x15mm Button Head Screws – Qty: 1
1010616 | Trimdeck Polycarbonate Roofing Cream 2.4M – Qty: 3
1010608 | Bastion Roofing Screws (25 Pack) – Qty: 2
4150178 | Pinnacle 200mm T-Hinges (2 Pack) – Qty: 2
0088421 | Goliath 1800mm Galvanized Piano Hinge – Qty: 1
0920085 | Buildex 12Gx50mm Roofing Screws (100 Box) – Qty: 1
0131442 | Zenith 200mm Black Gate Tee Hinges (2 Pack) – Qty: 2
4150164 | Pinnacle Black D-Pattern Gate Latches – Qty: 2
0217508 | Trojan 10mm Heavy Duty Staples (1000 Pack) – Qty: 1
0217503 | Trojan 3-in-1 Staple Gun – Qty: 1
Impact Driver / Power Drill
Hex Head Driver Bit
Spirit Level
Speed Square
Bevel Gauge
Tape Measure
Pencil
Circular Saw
Handsaw
Snips / Wire Cutters
Saw Stools
Ladder
Step 1: Cleared the ground, leveled the site, and constructed the heavy-duty base frame foundation using H4 clear-coated timber.
- Step 2:
Erected the main vertical wall studs and pitched roof rafters using structural H3 treated pine framing.
- Step 3:
Installed the moisture-resistant, heavy-duty Formply flooring sheet inside the main housing coop footprint. Built the nesting box and made the split door
- Step 4:
Installed the cream Trimdeck polycarbonate roofing sheets using hex head roofing screws. Cladded the exterior walls using precision-lapped Weathertex ruff sawn weatherboard panels.l, installed the colour bond roof, and painted the run and
- Step 5:
Constructed the custom drop-down side access panel using the Tee hinges and padlock bolts
- Step 6:
Wrapped the extensive 4.5m run structure with high-tensile aviary wire mesh, securing it tightly with button head screws and heavy-duty staples.
- Step 7:
Completed the final exterior trim installation, installed the auto chicken door and ramp, applied a deluxe surft mist and lined the interior with fresh pine shavings
