Starting with a Bunnings Mimosa Burleigh Wooden Gazebo, we set out to create something truely unique functional and cost effective. We fully enclosed and lined the structure, transforming it into a premium outdoor wellness centre complete with sauna, gym equipment, lighting and custom finishes. We wanted a dedicated space that promotes both physical and mental wellbeing without leaving our home. The project allowed us to maximise our outdoor area and build a year round retreat for fitness, relaxation and recovery. What was once a simple gazebo is now a standout.
The starting point was the Bunnings Mimosa 4.27 x 3.67 x 3.23 Burleigh Wooden Gazebo. From here we purchased all sorts of materials from Bunnings to complete this work of art!! Learning lots through the process!
Built from Ryobi gear from Bunnings. All handled the job well.
Step One: site preparation:
- Clear all existing grass and excavate to take concrete,
- Excavate for services, water, electrical, stormwater and surface drainage,
- Install inground services water, electrical, stormwater and surface drainage,
- Excavate footings and thickenings, and
- Lay plastic and mesh ready for concrete.
- Step 2:
Step Two: Place Concrete:
- Step 3:
Step Three: Prepare for Gazebo Installation:
- Prepaint all Gazebo components including posts, beams, trusses,
- Install Termite Protection and
- Waterproof slab edges.
- Step 4:
Step Four: Build Gazebo:
(Note prior to installing the roofing, I lined underside of roof and add insulation)
- Step 5:
Step Five: Build Infills to walls of Gazebo including:
- Framing Walls,
- Adding cyclone straps, tie-down bolts etc.
- Rewaterproofing and
- Sarking.
(Note lining left out central of ceiling to wire for lights, additional nogging placed to take wall sheeting which is a prefinished plastic not-plaster, so was more flexible)
- Step 6:
Step Six: Install Glass Sliding Door:
- Step 7:
Step Seven: External Linings and Persepex to close in ends of trusses:
- Also pose for photo with wife's toolbelt after breaking mine!
(Note to add guttering I had to increase the depth of the sides of the gazebo as they were not long enough to take standard guttering)
- Step 8:
Step Eight: Install Guttering and connect to stormwater:
- Step 9:
Step Nine: Insulate and Line Internal Walls and finish
Ceilings:
- Step 10:
Step Ten: Final Fitoff:
- Finish lining walls,
- Install trims,
- Finish painting,
- Final Fit Electrical,
- Install Timber Hybrid Flooring,
- Install curtain,
- Place in Sauna, gym equipment and
- Enjoy!!!
