I wanted a clean and practical shelf in the entrance area after repainting and reflooring the complete house.
I made and installed this custom shelf with drawer
Merbau sheet 18mm and 26mm.
Drawer slides
Screws
Glue
Wall plugs to anchor to the wall
Sand paper
Cabot's clear polyurethane
Tape measure
Spirit level
Drill and drill bits
Drop saw
Table saw
Router and round over bit
Pocket hole jig and screws
Spacer / packer to hold drawe off the bottom to install drawer slides
Design - The design was fundamental. I wanted it to fit the wall perfectly with no screws, nails or drawer handles seen in the build or attachment to the wall. It needed the corner rounded as it is a thoroughfare a sharp edge was less than desirable.
So with a tape measure, pencil and paper the many versions were sketched until I was happy with the design.
- Step 2:
I rough cut all timber oversize from the large sheets.
I then marked the back and top in situ to match the actual size and angle of the walls (knowing they are never perfect square).
Once I had these fitting without gaps it was a case of making the rest to suit.
- Step 3:
I then pulled it all apart to sand and clear coat all parts so all the sides of all components were sealed.
- Step 4:
Reassembled the shelf and drawer with glue and screws.
- Step 5:
Installed the shelf with screws into studs where it was possible and wall plugs when not possible from inside the shelf where the drawer would be into both the back and side walls for strength.
Installed the shelf and the project was completed.
- Step 6:
