I built this DIY wall panelling to give our entryway a more modern, stylish look without spending a fortune. Using MDF strips, I created a vertical panel design, then filled, sanded and painted it for a seamless finish. The project was an affordable way to add character and completely transform a plain wall, and I’m really happy with how clean and professional the end result turned out.
1-
https://www.bunnings.com.au/easycraft-12mm-2700-x-133mm-white-mr-mdf-e0-primed-easylining-shiplap-general-purpose-lining-board_p0493222
2-
https://www.bunnings.com.au/42-x-18mm-5-4m-white-moulding-pine-fj-primed-dar_p0020749
3-
https://www.bunnings.com.au/british-paints-white-gloss-h2o-enamel-paint-4l_p1420303
4-
https://www.bunnings.com.au/selleys-320g-liquid-nails-construction-adhesive_p1233751
5-
https://www.bunnings.com.au/zenith-8-10-x-50mm-galvanised-countersunk-rib-head-timber-screws-500-pack_p2420877
6-
https://www.bunnings.com.au/uni-pro-500g-multi-purpose-interior-filler-500g_p1210281
1-
https://www.bunnings.com.au/ryobi-18v-one-hp-165mm-brushless-circular-saw-rcs18c-tool-only_p0405164
2-
https://www.bunnings.com.au/paint-partner-4-piece-paint-brush-set_p0794487
3-
https://www.bunnings.com.au/ryobi-18v-one-drill-driver-starter-kit-r18dd22_p0715241
4-
https://www.bunnings.com.au/ryobi-150-piece-driving-kit_p0393551
5-
https://www.bunnings.com.au/uni-pro-skeleton-caulking-gun_p1670517
6-
https://www.bunnings.com.au/stanley-200mm-plastic-torpedo-level_p0132284
7-
https://www.bunnings.com.au/craftright-8m-tape-measure_p5660481
Measured the wall and planned the spacing for each vertical panel
- Step 2:
Cut the MDF moulding to the required lengths
- Step 3:
Marked the wall with a level to ensure all panels would be straight
- Step 4:
Applied Liquid Nails to the back of each MDF strip and fixed them to the wall, using a nail gun where needed to hold them while the adhesive cured
- Step 5:
Filled all nail holes and joins with timber filler and caulked the edges for a seamless finish.
- Step 6:
Filled all screw holes and joins with timber filler and caulked the edges for a seamless finish.
- Step 7:
painted the panelling and wall with Three coats of gloss white paint
- Step 8:
Allowed the paint to dry before styling the space with artwork and décor
