First was the steel framing made from C channel 75mm x 40mm
Covered inside wall with structare ply and covered with VJ panel
Made steel frame 150mmx 50mmx 2.4mm to place the kaboodle cabinets on, installed them with specrite 2400mmx 600mmx 33mm for bench top and sides of cabinets
Installed sink and taps, painted wall blue and clear epoxy resin to the bench top
Installed Polar aluminium shutters half wall above the BBQ and full size section to fill in side wall
power points 3 doubles one single, TV aerial coaxial cable and internet connection
Built bulkhead above TV wall to cover cable and water pipe entry
Placed heat lamp under couch, and wood stove that was taken out of our old house, restored and erected with complete flue kit purchased from Bunnings
The only extra hand I had was the plumber to connect hot and cold water, im an electrician and done the wiring myself
Now we watch footy, cook great food and enjoy the warmth from the stove and bar heater
Kaboodle cabinets 3 single with draws 1 double door
150mm x 50mm steel beams
Structure form ply 2400 x 1200 x 19mm
Specrite 2400 x 600 x 30mm
VJ panel 2400mm x 1200mm
150mm x 19mm wood for bulk head
Black sink, black tap ware sink drain pipe
Water Proof outlets, 2.5mm 2C+E cable, coaxial cable
Aluminium shutters, also aluminium angle and flat bar both 40mm, and aluminium 50x 25mm tubing
Paint (blue, white), silicon, poxy resin
BBQ matador 6 burner
Full flu kit for wood stove, bar heater 2400W
Wood screws, metal screws, pop rivets, sand paper
Every tool in my shed, all battery makita hand tools, carpenters, electrician, plumbers, metal fabrication and finishing tools
Circ saw, hamer drill, drill, impac driver, multi tool, welder, hole saws, level, square, straight edge, plies, screwdrivers, hamer, pipe rench, clamps, ladder, tin snips, grinder, pop rivet gun, silicone gun, stanly knife, insulation resistance tester,
Made wall frame from steel channel
Covered with non structural ply
Connected waste drain to ATU, hole saw through paver and dug under pavers to run waste water pipe under pavers rising into bottom double door cupboard
- Step 2:
Welded steel frame to stand cupboards on
Built and installed cupboards
Covered back wall with VJ panel
Secured bench top and cut out sink and tap entries
- Step 3:
Installed aluminium shutters
Ran power and coaxial cable and connected power points and TV point
Painted VJ panel, and clear poxy resin
- Step 4:
Plumber connected hot and cold water
Built Metador BBQ
- Step 5:
Made frame for wood stove and set up stove in place
Erected fire flu to stove through ceiling, made secure on roof
- Step 6:
Installed bar heater, ran power to power point under ceiling
- Step 7:
Hung TV
Invited friends around, watched footy, cooked BBQ with couple drinks
