Our bathroom suffered a serious waterproofing failure, leading to a full renovation. What started as a minor leak turned into mould, cracked and lifting tiles, and constant water ingress no amount of patching could fix. Temporary fixes kept failing, so we stripped everything back and rebuilt properly. We removed all old tiling, re-waterproofed from the substrate up, and replaced outdated fittings. Where we could, we reused rather than bought new: the mirror was upcycled with paint, the vanity base and top were second-hand, and part of the shower glass was salvaged, with the rest cut to order.
Barelli Piazza Matte Black Single Robe Hook - https://www.bunnings.com.au/barelli-piazza-matte-black-single-robe-hook_p0108325
Mondella Matte Black Rococo Multifunction Twin Shower - https://www.bunnings.com.au/mondella-matte-black-rococo-multifunction-twin-shower_p0666494
Dulux White Ceiling +PLUS Kitchen And Bathroom Paint - 1L - https://www.bunnings.com.au/dulux-white-ceiling-plus-kitchen-and-bathroom-paint-1l_p1370218
Selleys 180g Spakfilla Rapid Gap Filler - 180g - https://www.bunnings.com.au/selleys-180g-spakfilla-rapid-gap-filler-180g_p1231864
Selleys 475g No More Gaps Interior Multipurpose Gap Filler - 3 Pack - https://www.bunnings.com.au/selleys-475g-no-more-gaps-interior-multipurpose-gap-filler-3-pack_p1232399
Rust-Oleum 2X Ultra Cover Satin Canyon Black Spray Paint 340g - https://www.bunnings.com.au/rust-oleum-2x-ultra-cover-satin-canyon-black-spray-paint-340g_p1580677
Dulux 4L Lexicon Quarter Low Sheen Ready To Go Colour Wash&Wear Interior Paint - https://www.bunnings.com.au/dulux-4l-lexicon-quarter-low-sheen-ready-to-go-colour-wash-wear-interior-paint_p0638877
British Paints White 4 In 1 Prep Water Based Primer Sealer Undercoat - 500ml - https://www.bunnings.com.au/british-paints-white-4-in-1-prep-water-based-primer-sealer-undercoat-500ml_p1420371
Duratile 30 x 60cm White Gloss Ceramic Wall Tile - 8 Pack - https://www.bunnings.com.au/duratile-30-x-60cm-white-gloss-ceramic-wall-tile-8-pack_p6661134
Duratile 30 x 60cm London Black Porcelain Floor Tile - Carton 6 - https://www.bunnings.com.au/duratile-30-x-60cm-london-black-porcelain-floor-tile-carton-6_p0271116
Barelli Piazza 600mm Matte Black Single Towel Rail - 600mm - https://www.bunnings.com.au/barelli-piazza-600mm-matte-black-single-towel-rail-600mm_p0108318
Mondella Matte Black Rococo Toilet Roll Holder - https://www.bunnings.com.au/mondella-matte-black-rococo-toilet-roll-holder_p0115748
Mondella Black Matte Resonance 1/4 Turn Pin Lever Wall Top Assembly - https://www.bunnings.com.au/mondella-black-matte-resonance-1-4-turn-pin-lever-wall-top-assembly_p0684110
Arlec 250mm White Exhaust Fan - https://www.bunnings.com.au/arlec-250mm-white-exhaust-fan_p4440572
Arlec 9W 92mm Tri-Colour Dimmable LED Downlight Flushed Lens - 10 Pack - https://www.bunnings.com.au/arlec-9w-92mm-tri-colour-dimmable-led-downlight-flushed-lens-10-pack_p0563589
DETA X6 Gloss White Double Vertical Switch - https://www.bunnings.com.au/deta-x6-gloss-white-double-vertical-switch_p4331839
Dunlop 310ml Coloured Silicone - Midnight - https://www.bunnings.com.au/dunlop-310ml-coloured-silicone-midnight_p6829670
Davco 20kg SMP Evo Tile Adhesive - https://www.bunnings.com.au/davco-20kg-smp-evo-tile-adhesive_p6650266
Dunlop 5kg Flexible Coloured Grout - Charred Ash - https://www.bunnings.com.au/dunlop-5kg-flexible-coloured-grout-charred-ash_p6829824
DETA Double Powerpoint - Single Pack - https://www.bunnings.com.au/deta-double-powerpoint-single-pack_p4430414
Estilo Close Coupled Rimless S Trap Toilet Suite - https://www.bunnings.com.au/estilo-close-coupled-rimless-s-trap-toilet-suite_p0066063
Monarch 270mm Comfort Grip Roller Frame - https://www.bunnings.com.au/monarch-270mm-comfort-grip-roller-frame_p1560517
Monarch 270mm Walls And Ceilings Ultra Microfibre Roller Cover - https://www.bunnings.com.au/monarch-270mm-walls-and-ceilings-ultra-microfibre-roller-cover_p1660033
UNi-PRO 50mm You Can Do It Angled Sash Cutter Brush - https://www.bunnings.com.au/uni-pro-50mm-you-can-do-it-angled-sash-cutter-brush_p0019773
Paint Partner 50mm Paint Brush - https://www.bunnings.com.au/paint-partner-50mm-paint-brush_p0794476
DTA Rubber Pointed Trowel - https://www.bunnings.com.au/dta-rubber-pointed-trowel_p6655396
QEP 8mm Square Notch Handyman Adhesive Trowel - https://www.bunnings.com.au/qep-8mm-square-notch-handyman-adhesive-trowel_p6650392
QEP Jumbo Wedge Tile Spacers - 250 Pack - https://www.bunnings.com.au/qep-jumbo-wedge-tile-spacers-250-pack_p6821949
QEP 3mm Cross Tile Spacers - 800 Pack - https://www.bunnings.com.au/qep-3mm-cross-tile-spacers-800-pack_p6659528
QEP 600W Master Cut Tile Saw - https://www.bunnings.com.au/qep-600w-master-cut-tile-saw_p6654641
Demolished the bathroom back to the brickwork, removed all old tiles, fittings, and the failed waterproofing membrane, exposing mould damage underneath.
- Step 2:
Repaired and prepped the substrate, then applied a full waterproofing membrane to floor and walls, paying close attention to corners, the shower recess, and penetrations.
- Step 3:
Replaced the electrical fittings with new including an exhaust fan, downlights, a double powerpoint, and a light switch before wall linings went back up.
- Step 4:
Set out and laid the black porcelain floor tiles using tile adhesive, spacers, and a tile saw for cuts around fittings.
- Step 5:
Tiled the walls with white gloss ceramic tiles, using the same adhesive and spacer system for consistent lines.
- Step 6:
Grouted and siliconed all tile joints and the shower recess with flexible, coloured grout and silicone for a durable, waterproof finish.
- Step 7:
Filled, sanded, primed, and painted the ceiling and remaining walls, including upcycling the existing mirror with a fresh coat of black spray paint.
- Step 8:
Installed the toilet suite, shower mixer, and twin shower, then fitted the shower screen using salvaged glass on one side and a new pane cut to order for the rest.
- Step 9:
Fitted the second hand vanity base and top, reconditioned and reinstalled to suit the new layout. Fitted the taps and faucet.
- Step 10:
Finished with the fit off: robe hook, towel rail, and toilet roll holder, then a final clean to complete the transformation.
