This is where we refinished our fireplace surround to make it more modern and our style!
Davco SMP Evo Tile adhesive for the heavy sandstone rocks -
https://www.bunnings.com.au/davco-20kg-smp-evo-tile-adhesive_p6650266?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=21112196286&gbraid=0AAAAADtbEB97SQO1PEWSBkat3BPY0DFST&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0zAh_5n6N6XJFrAXDbvQsu-VpkhIN9qV06tS70bGsyLP_evbmvrFncaArUPEALw_wcB
Dunlop Wide Joint Grout -
https://www.bunnings.com.au/dunlop-15kg-mid-grey-wide-joint-grout_p0508303?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=21112196286&gbraid=0AAAAADtbEB97SQO1PEWSBkat3BPY0DFST&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0wxBg_xDAzfJia08ybs4Vhz0rbuOXjzG4yuGWqN-OQAoDd2MAYflEYaAn2IEALw_wcB
Sandstone rocks - 2m2 ordered locally
Acrylic paint to dye the grout we used a mix of orange, yellow, white & brown -
https://www.bunnings.com.au/boyle-100ml-yellow-artist-acrylic-paint_p0353433
Diamond blade for angle grinder to cut and shape stone -
https://www.bunnings.com.au/full-boar-115mm-turbo-rim-diamond-blade_p0227335?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=20298036952&gbraid=0AAAAADtbEB9ss3W-e98kn2JyDvsV0p8Jc&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0xnyOFgkKosGVLdgwNRY_9AnbgpG3v-tTZUsW9CExlnHS0qIWZZMOYaAi9kEALw_wcB
Ryobi angle grinder-
https://www.bunnings.com.au/ryobi-18v-one-115mm-angle-grinder-tool-only_p0509295
Metal Scraper to scrape off old faux brick and paint -
https://www.bunnings.com.au/trojan-100mm-paint-scraper_p0093214?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=20293637888&gbraid=0AAAAADtbEB_WV7Gl3n0oHX2xYUD6TGTcQ&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0xz1jmOO5Iiojy_TkZD0FyaN9IBkA_bSJ-5Jw1ipVQ-nw4N6nOUinwaAiWJEALw_wcB
Paint stripper -
https://www.bunnings.com.au/poly-1l-polystrippa-paint-stripper-1l_p1715074?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB8rxA4pEm65EoCfTAf8FRkZa&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0yAAra6VQWgwXZP_gAFgAaFyoA0RbgRrRSwqxAeQvehOkWLXRzCbIwaAg-gEALw_wcB
Paint Brush for applying Paint stripper-
https://www.bunnings.com.au/paint-partner-38mm-synthetic-paint-brush_p1662328?store=7021&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB8rxA4pEm65EoCfTAf8FRkZa&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0z7afA7_P-wvw8AsUwEJQ5qWo5s-10hsM-STmqLxhaDtdIxIloGHx0aAtb8EALw_wcB
Gloves-
https://www.bunnings.com.au/craftright-large-nitrile-glove_p0181833?store=7336
Ryobi Drill -
https://www.bunnings.com.au/ryobi-18v-one-drill-driver-starter-kit-r18dd22_p0715241?srsltid=AfmBOopnG1hmw8rD3r2jQWRwyy3Yz89OSP3E33uobUULux39iOsfnLrWDec
Mortar mixer attachment -
https://www.bunnings.com.au/ezitile-adhesive-grout-mixing-paddle_p0592160?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=21112196286&gbraid=0AAAAADtbEB97SQO1PEWSBkat3BPY0DFST&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0y5HWO_BsvWWDYZUGYDJNMUQqzv9aFOJsKSjRtEAIYQwuhf9AzahH0aAu-TEALw_wcB
Notched Tile Adhesive Scraper -
https://www.bunnings.com.au/qep-6mm-square-notch-plastic-adhesive-spreader_p6821486?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=21112196286&gbraid=0AAAAADtbEB97SQO1PEWSBkat3BPY0DFST&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0z2rOOHta1WZUCgJoM93Fcrm5MxYhzJMrjr6nKf6NWGU1hVOcC-jMMaAqhwEALw_wcB
Silicone Piping bags for Grout
Sponge-
https://trade.bunnings.com.au/dta-large-foam-sponge_p6826999?srsltid=AfmBOopjTGsEuGUMDE30aB--G2Mng_vkiHZ2ZMimeH1IckPqL2WjL8jj7Jk®ion_id=117336
Plastic bucket -
https://www.bunnings.com.au/9-3l-assorted-multipurpose-plastic-buckets-with-spout_p4461010?store=7336
Microfibre cloths -
https://www.bunnings.com.au/all-set-microfibre-cleaning-cloths-4-pack_p0874307?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=20876642384&gbraid=0AAAAADtbEB8glQeB1mvun8BH33vw85pi5&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0y3C420D115pHl6_lw7azdyLCg2p_7TkiyBwDsR4B46-MS1tlu0YPAaAqVwEALw_wcB
Wire Metal Brush-
https://trade.bunnings.com.au/trojan-brass-plated-wire-brush_p0093216?srsltid=AfmBOoojvwm5KmIseH_ifXPVxyqInm7SNT1H1Q2PyhTTLnMfy1_QZXExikE®ion_id=117336
Ryobi Heat Gun -
https://www.bunnings.com.au/ryobi-2000w-corded-heat-gun-ehg2000_p6210387
Hammer-
https://www.bunnings.com.au/trojan-8oz-225g-fibreglass-claw-hammer_p0492161?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB8AdemAum1gM2Ccw2Q7Eh0UJ&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0z3tYQzhW--Bzpy6T0olMz2QcCYYH3tka9ny9ahrCPz0dqK8h2_QGAaAmCaEALw_wcB
Drop Sheets plastic or canvas-
https://www.bunnings.com.au/paint-partner-3-7-x-3-7m-plastic-drop-sheet_p0328943?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB8rxA4pEm65EoCfTAf8FRkZa&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0zTfV2wZyf7yax50PiFxh9usNbUOQrwngrm4EJUolaYzGsFd9cElM8aAm_PEALw_wcB
https://www.bunnings.com.au/paint-partner-2-6-x-3-6m-plastic-backed-canvas-drop-sheet_p1660308?store=7336&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB8rxA4pEm65EoCfTAf8FRkZa&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0w0mzqr7Jd6BJ8tyeYFyPlqhtQJUiFie4Zlc02FguZsXweO9nL0pMwaAj0mEALw_wcB
Remove old gas heater or fireplace insert with tools and make sure gas is turned off by a licensed plumber or call in one to remove the unit. Remove other items from surrounding area and cover floor and furniture with plastic or canvas drop sheets as this will get very messy and dusty. Prepare tools to start scraping off old fake bricks, you will need scrapers & hammers.
- Step 2:
Using the scrapers and hammers get behind the old fake bricks and pry them off with the scraper and hammer pushing through the glue and lifting it off the original brick. Use a dustpan and broom to sweep up brick and put in plastic bags to dispose of. Once this has been done use the heat gun or paint stripper and paintbrushes to remove any other adhesive glue or paint layers.
- Step 3:
Lay out all your sandstone pieces and do a dry fit of how you want to start, starting from the bottom section. Then gather some of the next pieces going up on the front of the fireplace, (make sure these fit well and are placed ready to go on the floor infront). Then sort sandstone by sizes on the floor or in baskets. Then gather sizes that would be good for the thin sides of the fireplace near the wall. Once all this is laid out or in piles the move onto the next step.
- Step 4:
This next part you need to move quickly so your Tile Adhesive does not dry out, mix this in a bucket with the mixing attachment and drill and water then use your notched scraper to add this to the back of the sandstone pieces and the original brick working from the floor then up, you will need to hold each vertical piece for about 2-5 minutes each to ensure this quickly adheres to the bricks, once done each piece you can use off cuts of sandstone to hold each piece up on top of eachother vertically (for drying) when working on the surround. These are easy to get out later just don’t put too much adhesive near or around them.
- Step 5:
Once completed leave for two days to dry and set, remove small offcuts and prepare items for grouting. Wide joint grout, bucket, mixer attachment, piping bag, drill and acrylic paint. Mix this grout up and add paint to achieve the colour grout you desire. Apply the grout with a piping bag and use gloves to push deep into and around sandstone. Wipe the grout away as much as you can with warm water a sponge and microfibre cloths. Let set for two days then use wire metal brush to brush and dust around sandstone pieces, be careful not to scrub at the grout joints.
- Step 6:
Use the dustpan and brush then clean up the area, remove drop sheets and waste, get your new fireplace or heater fitted by a licensed plumber and electrician and enjoy!
