My budget was tight, Bunnings, Kaboodle and my son installing was the answer. Thanks to the many team members at Bunnings North Penrith NSW for all their expertise/customer service choosing the right items for the look that I dreamed of and that was achieved. Their guidance meant I came in well under budget, and I have finally got my dream kitchen which has been extremely rewarding for me from demolition to the finished project. Shout out to the many staff, and especially to Sharen the Kaboodle consultant who was so patient and professional with modifications to the original design.
- Kaboodle cabinets/drawers/handles/benchtop/kickboards
- Gyprock boards, joint tape, casting plaster
- Gyprock CSR 3600 Plasterboard RE
- Gyprock CSR 2400 Plasterboard RE
- Gyprock CSR 2400 Supaceil™ Plasterboard RE
- James Hardie 1800 Villaboard Lining
- Gyprock CSR Cove Plaster Cornice
- Gyprock CSR 5.5kg Acrylic Stud Adhesive
- Gyprock CSR 15kg Easy-Finish Topping Compound
- Gyprock CSR 20kg Cornice Cement 45
- Builders Edge 75m Perforated Plasterboard Jointing Tape
- Zenith Gold Passivated Countersunk Rib Head Chipboard Screws
- Hume 2100 Door Jamb
- STRUCTA floor General Purpose YellowTongue
- Sandpaper
- Timber skirting/architraves/window frames
- Nails/screws
- Liquid nails
- Door frame
- Door
- Door handle/lock/hinges
- Subway gloss Tiles
- Tile adhesive
- Tile grout
- No more gaps filler
- Spakfiller
- Expanding foam filler
- Paint rollers/tray/brushes
- Painters tape
- Painters drop sheets
- Duct tape
- Sink/tap/plumbing pipes
- Electric PowerPoints/down lights/light switches/ceiling lights
- Hybrid laminate flooring
- Sugar soap
- Bunnings Website…. I use Bunnings website to look up an item, check to see if it’s in stock, check ratings/reviews, take a picture on my phone, (it has the item number listed (I/N) flick it to my Bunnings album …...this process made it easy for a Bunnings team member to assist me, especially comparing products…...I leave rating/reviews for other customers.
Carpenter pencil
Plaster trowel/hawk/sander/joint knife
Electric drill/drill bits Battery charger
Sawhorses
Plaster sander
Measuring tape/ruler/L square/ Digital laser measure
Spirit level
Screwdrivers set
Clamps
Planer
Hammer
Drop saw/jig saw
Nail gun
Ladders
Laminate flooring cutter/tools
Earmuffs/ protective eyeglasses
Broom/dustpan/vacuum/blower vacuum/microfibre cloths
Power tool charger
Makita power tools were used
After consultation/design with the Bunnings Kaboodle consultant and delivery of the flat pack, demolition of the old kitchen left a shell to work with. Installation of the new walls (with electrics/plumbing) and ceiling were painted ready for the next step.
- Step 2:
Assembling the flat pack cabinets with easy-to-follow instructions ensured that this step of installation went smoothly.
- Step 3:
The bench top was the next to be installed, using the jigsaw for the stove top and sink cut out, then fit off of the appliances, electrics and sink completed the benchtops. The dining area had wall cabinets fitted as a narrow buffet with the same bench top to give an extended look inclusive to the small kitchen.
- Step 4:
Installing the new windows was a task, the dining area originally had a floor to ceiling windows which meant modifying the wall to fit the new window.
- Step 5:
The Hybrid laminated flooring was the next job to tackle before the kickboards added the finishing look.
- Step 6:
The splash back tiles were laid subway style and extended up the side of the wall cabinets to give a unique look. Kitchen complete!
