The bathroom received a complete aesthetic refresh without altering the layout. All surfaces were sanded and prepped, followed by new coats of Dulux paint suited to each material. Protected areas were covered, while metal fixtures were scratched down and finished with matte black spray paint for a modern touch. Attachments were upgraded, and a new vanity was installed, creating a brighter, cleaner, and more cohesive space with updated finishes and hardware.
• Fixed Pole Pro Renovator
• Pro Renovator Roller Kit
• Roller Kit You Can Do It
• Drop Sheet Paint Partner (x2)
• Masking Scotchblue Original
• PVC Duct Tape Paint Partner
• Kit Floor Rustoleum Home + SS White Base
• Sandpaper Roll Flexovit
• Paint Brush Blend
• Roller Cover Uni Pro
• Filler Multi Purpose
• Paint Cleanup
• Paint Int Dulux Wash&Wear Vivid White (x3)
• Monarch Task Roller Covers
• Mould Killer Selleys
• Spray Paint Rust-Oleum Matt Black
• Orbital Sand Disc
• Paint Frame Uni Pro
• Thread Seal Kinetic
• Paint Tray Uni Pro
• Paint Reno Floors Dulux Satin White
• Paint Reno Tilesabenches Dulux Satin White
• Silicone Wet Area Selleys White (x2)
• Connector Water Kinetic
• Silicone Wet Area Selleys Mid Grey
• Selleys Wet Area Silicone Black
No extensive power tools used, mainly just the ones listed above.
Preparation — Remove all movable items, tape off areas, and thoroughly clean the space. Sand all surfaces (walls, tiles, metal fixtures) to ensure good adhesion
- Step 2:
Surface Repair & Priming — Fill any cracks/holes, repair damaged areas, and apply appropriate primer to walls, tiles, and metal surfaces. Allow appropriate time for primer to dry.
- Step 3:
Painting — Apply new coats of paint: fresh white/ neutral on upper walls and ceiling, and the chosen accent colour (e.g., deep green) on lower walls and shower area. Allow each section to dry appropriately before moving onto next phase.
- Step 4:
Metal Hardware Refresh — Cover over completed sections to prevent black paint overspray. Lightly sand existing taps, shower fittings, and handles, then apply multiple coats of matte black spray paint. Allow full curing time.Work in a well-ventilated area, wear appropriate PPE, and allow proper drying times between coats
- Step 5:
Floor Update — Clean tiles thoroughly and paint or apply new border tiles/strip in the accent colour (green) around the floor perimeter.
- Step 6:
Shower and bath fittings upgrade — Install a new modern black coloured bathroom fittings. Ensure mains water supply has been turned off and seal with appropriate silicone filler.
- Step 7:
Vanity Replacement — Remove the old vanity and install the new wooden vanity with integrated basin and matte black tapware. Will need help from a licensed plumber to complete fitting for insurance compliance.
- Step 8:
Final Touches — Re-seal all joints with matching silicone, reinstall accessories, clean thoroughly, and add new towel racks.
