We needed a place for all the excess stuff a family accumulates with easy access for the smaller ones and out of reach access for us to store things. I built the bench seat with shoe storage cupboard first to hide the mountain of shoes by the door.
Hinges -
https://www.bunnings.com.au/hafele-105-soft-close-full-overlay-clip-on-hinge-1-pair_p0037939
Gas strut for top cupboard -
https://www.bunnings.com.au/goliath-325mm-150n-black-gas-strut_p4230058
MDF for cabinet frame and doors -
https://www.bunnings.com.au/18mm-mdf-panel-standard-2400-x-1200mm_p0590060
Thin MDF sheet for arch door shape -
https://www.bunnings.com.au/6mm-mdf-panel-standard-1200-x-900mm_p0590068
Plywood for bench seat -
https://www.bunnings.com.au/1200-x-1198mm-12mm-plywood-pine-premium-bc-grade_p0390211
Bench seat frame -
https://www.bunnings.com.au/70-x-35mm-framing-mgp10-untreated-pine-2-4m_p8030010
plywood for floating shelf -
https://www.bunnings.com.au/1200-x-596mm-9mm-plywood-pine-premium-bc-grade_p0390149
Shelf frame -
https://www.bunnings.com.au/30-x-18mm-1-2m-dar-rectangle-clear-pine_p0097596
Coved panelling -
https://www.bunnings.com.au/easycraft-18mm-2700-x-170mm-white-mr-mdf-e0-primed-easylining-cove-30-primed-general-purpose-lining-board_p0493161
Paint - Dulux Buff it Quarter
Oak Veneer - bench seat/floating shelf
Sealer -
https://www.bunnings.com.au/cabot-s-1l-satin-water-based-cabothane-clear-polyurethane_p1522384
Circular Saw -
https://www.bunnings.com.au/bosch-professional-2050w-turbo-corded-circular-saw-06015a2040_p0214479
Router
Drill -
https://www.bunnings.com.au/ozito-pxc-18v-cordless-10mm-compact-drill-driver-pxcdk-150-kit_p0049052
I built the bench seat frame first. Covered it in plywood. Then veneer and sealer.
Then the bottom centre shoe cupboard. This was painted
- Step 2:
I built the frame for the tall cupboard. Then added the doors, after cutting the arch detail in the thinner plywood and glueing it to the door. I used a router to create the finger pulls
. This was painted and sealed.
- Step 3:
I fixed the panelling to the wall with liquid nails and some screws into studs at the corners. Then painted
I created the frame for the floating shelf, then covered in ply, veneer and poly.
Constructed the long top cupboard added doors, hung and painted.
Then measure and cut the additional open box at the end, veneered, sealed and installed.
- Step 4:
Adding the gold hooks last.
