We had a boring backyard with lawn that was dead most of the time and full of weeds. I wanted a place where I could go and be surrounded by garden, take a cup of coffee and enjoy the peace and beauty of plants that make me feel comfort.
Treated Pine Sleepers -
https://www.bunnings.com.au/200-x-100mm-3-0m-treated-pine-sleeper_p8032716
Garden edging for mapping out the area for sand stone and garden
https://www.bunnings.com.au/saxon-100mm-x-10m-black-garden-edge_p0111367
3 Cubic metres of dirt to level the ground.
A Trojan Tamper to flatten out the dirt.
https://www.bunnings.com.au/trojan-205mm-tamper_p0057896
SandStone blocks
Off White Cement
https://www.bunnings.com.au/australian-builders-20kg-off-white-cement_p0135870
Concrete
https://www.bunnings.com.au/australian-builders-20kg-high-strength-concrete-mix_p0761537
Sand
https://www.bunnings.com.au/bastion-20kg-dried-sand_p0208298
Weed Mat
https://www.bunnings.com.au/pillar-1-8-x-25m-black-platinum-weed-control-mat_p3041573
Sleeper Pegs
https://www.bunnings.com.au/50mm-sleeper-peg-galvanised-steel_p1100763
Steel joiners
https://www.bunnings.com.au/galintel-outdoors-50-x-450mm-hot-dip-galvanised-retaining-wall-h-joiner-post_p0850040
Marking spray
https://www.bunnings.com.au/dy-mark-350g-white-landscape-chalk_p1580044
Weed mat pins
https://www.bunnings.com.au/strol-230mm-weedmat-pins-100-pack_p0322573
Road Base
https://www.bunnings.com.au/ki-carma-20kg-road-base-landscape-stones_p0130552
Mark out the area and begin to clear the grass off (Big job! Bigger than you think when you start). Then put in the pine sleepers and weed mat using the pins. Bring in the dirt and level off the area. Then mark out the garden beds and add in the edging.
- Step 2:
Layout your sandstone blocks so they look somewhat decent enough for you to go, 'Oh that looks nice'. Cement them in on a base of Road Base. Check the levels so that they are all flat to each other. When they are fully dry start making the Off White Cement. I used a watering can to pour the cement in between the stones to allow full coverage. Make the cement about the same as thick cream. You'll need two people, one to make the cement and pour while the other goes around with a bucket of water and a sponge to clean off the excess and any drips. This could take up to three days so pace yourself.
- Step 3:
Once the cement is fully dry then start adding the plants and garden soil. Make the Bunnings Bench
https://www.bunnings.com.au/diy-advice/outdoor-living/outdoor-furniture/how-to-make-a-wooden-diy-garden-bench
My final advice - Add all year round colour because you'll be spending every season here. 😉
