A leaking toilet that turned into an unintentional ensuite renovation! By adding vj lining as a dado it created lots of texture and fitted the vibe i wanted. I kept the vanity cabinet and replaced the top and taps, added some black accents and painted. I also replaced the vinyl floor with tiles & replaced the toilet. I made the hardwood shelf, rounding the edges for a plant shelf and recycled some old decking to make the bathroom bench
Tile underlay
https://www.bunnings.com.au/hume-prima-ceramic-tile-underlay-1800-x-900-x-6mm-1-62sqm_p0710334
VJ 100 9mm wet area lining
https://www.bunnings.com.au/easycraft-easyvj100-wet-area-9mm-2400-x-1200mm-umr-mdf-e0-primed-white_p0166124
Waterproofing and primer
https://www.bunnings.com.au/crommelin-1l-one-coat-rapid-under-tile-waterproofing-membrane_p0356887
Dulux grey green paint for vj lining, vivid white for walls
https://www.bunnings.com.au/dulux-4l-interior-paint-wash-wear-plus-kitchen-bathroom-low-sheen-vivid-white-4l_p1370128
Vanity Top 1200mm
https://www.bunnings.com.au/mondella-1200mm-rococo-ceramic-vanity-basin-with-1-tap-hole_p4844305
Vanity mixer tap
https://www.bunnings.com.au/mondella-resonance-25mm-matte-black-curved-spout-basin-mixer_p0684122
Floor tiles - Bowral feature charcoal 300 x 300 Black Shower Set
https://www.bunnings.com.au/mondella-resonance-matte-black-5-function-hand-shower-and-1-2-twin-shower-set_p0684067
Selleys Wet Area white siliconehttps://www.bunnings.com.au/selleys-300g-white-wet-area-waterproof-silicone-sealant_p1230981 Skirting and moulding material i already had, black vanity knobs and hooks from Bunnings
Ryobi brad nailer (one of the best purchases ive ever made)
https://www.bunnings.com.au/ryobi-18v-one-18ga-c1-brad-nailer-tool-only_p0385367
Ryobi sliding mitre saw
https://www.bunnings.com.au/ryobi-2000w-254mm-dual-bevel-sliding-mitre-saw_p0087774
Makita circular saw
https://www.bunnings.com.au/makita-18v-165mm-brushless-circular-saw-dhs680z-skin-only_p6240314
Original ensuite pre water leak from toilet
- Step 2:
Toilet removed, floor boards and damaged plaster replaced, cement sheet down
- Step 3:
VJ lining installed and painted, waterproofing complete and tiles laid by a professional
