Our flooring has started to peel up at the edges over the past few months since we moved in. Just wondering how to repair?
Hi @floorlighter67,
It looks like the timber look veneer on your vinyl plank flooring has started to pull away from the core of the floorboard beneath.
My suggestion would be to apply a small amount of a high strength glue such as https://www.bunnings.com.au/sika-125g-sikabond-techgrip-high-strength-multi-purpose-polyurethane-adhesive-125g_p1660985 , press it down, wipe away any glue that squeezes out while it is still wet, then apply something heavy, such as some books or a weight plate over the glued section while it cures.
Make sure you leave the heavy object in place for 3-4 hours before removing it.
