I renovated the front of our old sandstone home to restore its character and create a welcoming entrance. The original windows and timber had weathered over time, so I stripped, repaired, and refinished them instead of replacing them. I wanted to preserve the home’s history while improving its appearance with a limited budget. The project was driven by a love of DIY, a desire to learn new skills, and the satisfaction of bringing an old home back to life for my family.
Everything was purchased through Bunnings.
Cabot’s water-based clear varnish to protect the restored timber
Posts that are where the wall once was.
From sand paper, timber filler, primer and exterior paint, scrapers, Paint rollers to brushes.
#9314885407504 PAINT KIT W/TRAY UNI PRO
230MM W/2 BRUSH HLDRS 407502
#9300697115263 GAP FILLER SELLEYS
475G NO MORE GAPS WHITE
#0038121 PAINT ENAMEL BP PAINT&PRIME
2L SG WHITE
#0407442 PRORENOVATOR BRUSHES
50/63/50 3 PACK
#0760517 MORTAR MIX DINGO
10KG BAG FAST SET 900404^
#0760509 CONCRETE HI-STRENGTH DINGO
10KG BAG FAST SET 900403^
2 @ $12.48
#0642925 DULUX CONCRETE & PAVING ROLLER
CRUSHED PEBBLE FINISH 230MM
#1670110 DROP SHEET MONARCH
2. 6MX3. 6M BLUE PLASTIC
#1560821 TURPENTINE MINERAL DIGGERS
1L16010-1DIG
#0836903 BUNNINGS
#I/N: 0961395 Bondall 4L BondCrete Cement Additive
#I/N: 1520267Cabot's 2L Clear Satin Exterior Timber Finish
#I/N: 0503054 Pryda 100mm M10 Heavy Duty Bolt Down Post Anchor
#I/N: 0506068 100 x 100mm 3.6m H4 Green EcoWood Tan-E Post
#I/N: 1523738 Cabot's 90g Natural Wood Tone Putty
#I/N: 1210468 Flexovit 115mm x 5m Timber Sandpaper Roll
UNi-PRO 50mm Real Good Paint Scraper
Ozito 200W Detail Sander
Pro Renovator 50mm Trim Paint Brush
- Cleaned and assessed the front of the house and fence.
- Stripped old paint and finishes from the timber windows and trims.
- Sanded all timber surfaces to prepare them for restoration.
- Repaired damaged timber and patched areas where needed.
- Restored damaged sandstone and mortar around the front façade.
- Primed the timber to create a long-lasting finish.
- Painted the trims and restored the home's original character.
- Restored the front fence by repairing, preparing, and repainting it.
- Applied a protective clear finish to the restored timber and sealed gaps around the windows.
- Completed final touch-ups, cleaned the site, and admired the transformed front of the
home.
