hi! I’ve just pulled up some carpet in my 1965 home
found these floorboards underneath, I’ve been told by others they are cypress pine.
I have removed all staples left by the carpet removal, and punched in all the nails.
Questions:
What is my sequence of steps? Sanding, filling in nail holes, sealing the floor. Which order do I do these steps in?
What can I use to fill in the nail holes? Is timber mate wood filler non shrinking a good choice?
do I use the same stuff I use for the nail holes to fill in the gaps between the floor boards (pictured) as well?
When sanding- I plan on hiring a sander and edger from Bunnings- what order should I use the sand papers and different grits in? Do I use edger first and then main sander?
I like the color of the floorboards so I don’t want to stain them. Can I just seal them without staining? What sealer should I use? Do I have to sand after sealing?
And before I do any of this should I clean the floor first? Like mop it?
I also live in a town with clay soil so there’s quite a bit of movement in my house as the weather changes so the floors move if this makes a difference as to how I would do things
thank you for any advice!!!
