We had an old asbestos shed and green house in the back corner of the yard. I decided to replace it with a new shed that has now turned into a studio rather than just a garden shed. I pulled down the old one and used the foundations for the new build. It is painted in colours the same as the house and now has Electricity (licensed electrician) and a tank connected to it. I am a small lady 5 foot 2 inches tall and 62 years old and am very pleased with the result
Materials from Bunnings are numerous including numerous galvanised screws and brackets
Insulation -
https://www.bunnings.com.au/earthwool-r6-0-ceiling-batt-275-x-580-x-1160mm-7-40m-11-pack_p0810607
Bosch driver and Drill -
https://www.bunnings.com.au/bosch-18v-professional-brushless-110nm-hammer-drill-1x5-0-ah-kit_p0426039
https://www.bunnings.com.au/bosch-18v-professional-impact-driver-kit-0615990m58_p0260175
Bosch Jigsaw -
https://www.bunnings.com.au/bosch-18v-professional-jigsaw-06015b3040-skin-only_p0515832
Makita slide saw -
https://www.bunnings.com.au/makita-260mm-10-1-4-slide-compound-mitre-saw-ls1110f_p0575872
Ryobi circular saw -
https://www.bunnings.com.au/ryobi-18v-one-165mm-circular-saw-r18cs-0-skin-only_p6210595
Ryobi reciprocating saw -
https://www.bunnings.com.au/ryobi-18v-one-compact-reciprocating-saw-tool-only_p0991763
Dismantled the old shed, had to get the asbestos removed by professionals
- Step 2:
Constructed foundations.
Dug several holes 600mm deep, concreted in stirrups, and used some of the original sheds foundation stumps
- Step 3:
Attached floorboards to the foundations
That is me hard at work
- Step 4:
Constructed the frame and stood it up making sure it is nice and square
- Step 5:
Added the roof frame
Me up on the ladder
- Step 6:
Put in the windows and put insulation foil around the whole building and roof
- Step 7:
put on the weatherboards, installed the door and put on the tin roof
- Step 8:
Painted weatherboards, dug the trench for electrical, had it wired and added tank to side unseen
- Step 9:
Built deck and small front verandah - Carlos is helping
- Step 10:
Insulated the walls and will get plaster and electrical professionally done and then do the architraves and paint it
