We found a vintage cedar front door that was a Hampton style, selling for $100. It was so much less than a new one. A little elbow grease, paint stripper, sandpaper, and the door was coming back to life. Primer, fresh coat of paint and new handles/locks…looks like new and brings so much light into the space! Goes great with the new board and batten look!
Paint stripper https://www.bunnings.com.au/poly-1l-polystrippa-paint-stripper-1l_p1715074?store=6459&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB8bMSUmuKFxCSUw7lKjC-g-L&gclid=CjwKCAjwmozTBhAeEiwAkEGZzlJOGLzwrGcucz00oXZ9rkfJdbKcjycTL1DHQUyWTiHLP6epPbwttRoCeDIQAvD_BwE
Sandpaper https://www.bunnings.com.au/flexovit-230x280mm-240-grit-timber-and-paint-sanding-sheets-5pk_p0272125
Dulux exterior paint- Colourbond Night Sky https://www.bunnings.com.au/dulux-4l-vivid-white-low-sheen-weathershield-exterior-paint-4l_p0144763?store=6459&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB8bMSUmuKFxCSUw7lKjC-g-L&gclid=CjwKCAjwvZHTBhAlEiwA1ug5P0mLl30CttuQFaBFFg_6qiCpMTA6JkLwjykfetavMs4T2Uu5s1tLJRoCevIQAvD_BwE
Primer https://www.bunnings.com.au/dulux-4l-1step-prep-primer-sealer-undercoat_p1370234?store=6439&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB8bMSUmuKFxCSUw7lKjC-g-L&gclid=CjwKCAjwvZHTBhAlEiwA1ug5PzBGm2rgPAnl3KyiOKNB1wcu48ZgkZvc5P8ppI_amdlykIhCGfSrjBoC4iMQAvD_BwE
Ozito sander https://www.bunnings.com.au/ozito-230w-random-orbital-sander_p6290233
Heat gun https://www.bunnings.com.au/ozito-2000w-variable-temperature-heat-gun_p6290265
Trim router https://www.bunnings.com.au/makita-6-35mm-1-4-710w-router-rt0700cx_p6240215
Hinges https://www.bunnings.com.au/austyle-100-x-75-x-2-5mm-316-marine-grade-stainless-steel-hinge-fixed-pin-ea-45216_p0119738
Scrapers https://www.bunnings.com.au/trojan-100mm-paint-scraper_p0093214
Tape https://www.bunnings.com.au/scotch-24mm-x-55m-rough-surface-extra-strength-painter-s-masking-tape_p1214133
Paintbrushes https://www.bunnings.com.au/monarch-50mm-walls-doors-and-trims-paint-brush-50mm_p1660270
Finding the door was a process. We had a few that we found that were too damaged, but then this one was perfect. It needed a bit of love to be brought back to life.
Stripping the paint was not an easy task. It took a lot of hours and lots of scrapping to get the door down to its original wood
Here it is stripped back to the original wood on the other side
Then it was time to put on the primer, giving a hint at the final look.
Then it was time to see the Night Sky on the front door too
Took some time to get it hung properly but it definitely finished off the front of the house nicely. And the frosted window panes bring so much light into the house.
The Night Sky finish looks fantastic against the board-and-batten exterior, @sohnlefamily.
Restoring a vintage door was a clever way to add character to the front of your home.
Thanks for sharing your project.
