Transforming the small closed in veranda room into my dream creative office. After having a builder move the windows I added VJ panelling, wallpaper and bright paint colours to redecorate the space.
VJ panelling
https://www.bunnings.com.au/2400-x-1200mm-9mm-lining-panel-white-mdf-primed-vj-100mm-2400mm_p0281911
Stanley knife
https://www.bunnings.com.au/stanley-retractable-trimming-knife_p5761184
Wallpaper Tools
https://www.bunnings.com.au/uni-pro-wallpaper-smoother-and-straight-edge_p1661659?store=6156&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB8bMSUmuKFxCSUw7lKjC-g-L&gclid=CjwKCAjwvZHTBhAlEiwA1ug5PwN3EK7y83PiZLJIWc47vNa4DLmPXHO9-t56NiE0M2_0QMUucf5YzRoCZSEQAvD_BwE
https://www.bunnings.com.au/morgan-jumbo-sponge_p4460815
https://www.bunnings.com.au/uni-pro-30mm-seam-roller_p1662302
https://www.bunnings.com.au/paint-partner-230mm-paint-roller-kit-230mm_p0328959
https://www.bunnings.com.au/selleys-350g-heavy-duty-liquid-nails_p1210564
https://www.bunnings.com.au/british-paints-white-4-in-1-prep-water-based-primer-sealer-undercoat-500ml_p1420371
https://www.bunnings.com.au/taubmans-1l-white-semi-gloss-water-based-enamel-paint_p0147167
Attach panelling using liquid nails.
- Step 2:
Prime all area for painting using 4in1 primer.
- Step 3:
Paint panelling using enamel paint.
- Step 4:
For wallpapering measure and cut panels of wallpaper as you go.
Use a roller to spread glue across the wall.
Line wallpaper up with the previous panel.
Smooth out bubbles and extra glue using wallpaper smoother.
Glide a damp sponge across the panel to clean up extra glue and smooth out.
Lightly roll seam roller over the seam line between the panels of wallpaper.
