Gabriella’s bedroom started with 70s damaged walls covered in dents, holes and old patch repairs. I repaired every imperfection, sanded the walls smooth, and transformed the space with Dulux Nambucca Heads at 75% strength for a soft, calming backdrop (after trying about 7 different samples from different brands!) I finished the room with simple, long rectangular moulding boxes to add timeless character and emphasise on the cozy and elongated character while giving a feeling of height. I painted everything for a seamless look. Every material was sourced from Bunnings, creating a beautiful bedroom that’s elegant, cosy and perfect for a growing little girl, with her favourite colour :)
- Dulux Nambucca Heads paint (75% strength)
- Dulux primer/sealer
- Timber moulding trims - Bunnings 15mm
- No More Gaps gap filler
- Selleys Spakfilla
- Sandpaper (various grits) 180 200 220
- Miter saw
- Paint rollers and roller sleeves
- Paint brushes (monarch were my favourite)
- Painter’s tape scotch blue
- Drop sheets!!
- Paint trays
- Liquid nails selleys
- Various samples of paint
Measuring tape
- Mitre saw (or mitre box and saw)
- Nail gun or hammer
I used a 10cm piece of wood to be able to measure perfect distance between rectangles - Caulking gun
- Putty knife
- sanding block
- Spirit level
laser level - however I found that I was better off with the 10cm wood piece - Paint roller frame
- Paint brushes
- Pencil
I cleaned the walls with hospital grade disinfectant and Shelley sugar soap liquid, Removed all existing nails and shelves from previous owner, repaired all holes, filled, and repaired damaged wall areas.
- Step 2:
I sanded all the walls again and again, refilled and sanded until smooth (definitely the least favourite step)
- Step 3:
I started measuring my mouldings and trims rectangles specifically to have three on each wall and be scaling with the room, calculated the best size of trim to also match the scale
- Step 4:
bought mouldings and cut all of them the right size with 45 degree angles
- Step 5:
I fixed all the mouldings according to measurements and previous crayon planning on wall, with the liquid nails and tape
- Step 6:
I sealed all the gaps with no gap sealer :) this was sportive! But I actually loved this step as I could the the trims take shape
- Step 7:
I lightly sanded the finished mouldings and the existing skirtings, also added some wood filler to some tiny areas and sanded
- Step 8:
I then painted all the walls and trims with the Dulux primer!
- Step 9:
I then painted all the walls in Dulux Nambucca heads 75%,
and painted the trims and the skirtings in semi gloss Nambucca heads 100% to give shape relief and even more interest to the mouldings
- Step 10:
I then had some happy tears as the colour was even more beautiful than thought, we installed all her little toys and a nice light carpet, and bed.
We have the best time in this room, the colour and mouldings makes it really relaxing and special day and evening.
