This display cabinet was "roadkill" on the side of the road so I brought it home to give it a new life. The doors were missing I so had to figure out a plan of action which was to cut out the middle section and join the two ends to make one enclosed unit. I love the art deco period so this has been a labour of love.
I am a 73 year old retired housepainter and all paints used are old stock that was on hand - some older than 15 years!
Selleys Wood Putty
Timbermade Wood Filler
Parfix Gap Filler
Parfix maxi nails,
Wood Screws
Taubmans 2 in 1 primer sealer undercoat
Wattyl Solargard low sheen "night Sky"
Dulux Was'n Wear matt "Fresco Blue"
Clear golss concrete sealer
sandpaper 80,120, and 180 grit
20mm half round quad
6mm MDF
Ryobi cordless drill/driver
hand saws
screw drivers
paint scrapers and filling baldes
paint brushes 63mm, 50mm & 20mm
artist brushes
Put cabinet in the car and brought it home
- Step 2:
After removing the glass overlay I cut out the middle section with a hand saw and with wood screws
joined the two end pieces to form one unit.
- Step 3:
Sanded all surfaces with 80 & 120 grit sandpaper and undercoasted with Taubmans 3 in 1 primer sealer undercoat.
- Step 4:
Sanded it again with 120 grit sandpaper and undercoated the exterior with grey tinted Taubmans 3 in 1 primer sealer undercoat.
- Step 5:
Filled all gaps with Parfix gap filler, filled cracks and holes with Timbermade wood filler and sanded smooth and undercoated.
- Step 6:
Applied 3 coats of British Paints low sheen interior white to the inside and cut the protruding middle section flush with the top of the cabinet.
- Step 7:
Applied 3 coats of Wattly Solargard low sheen "night Sky" to the exterior surfaces.
pplied 3 coats of Wattly Solagard low sheen "Night Sky" to the exterior surfaces.
- Step 8:
Applied 3 coats of Dulxu Wash ' n Wear matt "Fresco Blue" to trim pieces and 3 coats of clear gloss concrete sealer over that. I then attached the door handles and escutcheon plates.
- Step 9:
Glued "Fresco Blue' trim pieces to cabinet with Parfix Maxi Nails.
Job Done!
