Transformed the interior by installing decorative wall panelling to create striking feature walls and add warmth, texture, and character throughout the living space. A custom barn door was incorporated to maintain the benefits of open-plan living while providing the flexibility to create a private room when needed. The project enhanced both the functionality and visual appeal of the home, delivering a contemporary, versatile space that balances openness with privacy and creates a stylish, welcoming atmosphere.
porta dressed board 30x18mm I/N 8260130
porta pine dressed board 42x18mm I/N 8480061
porta 30x30 primed pine round edging I/N 0497531
surround by laminex 2400x1200 9mm lining white mdf I/N 0281911
Taubmans white semi gloss lexicon 1/4 professional interior paint
2x hume doors 2040x720x35 internal door Accent I/N 1970130
Dulux Aquanamel semi gloss
Easy coat sealer and undercoat Taubmans
paint brush
paint roller
6mm concrete drill bit
10mm concrete drill bit
IKONIC 2000x40x6mm matte black 2 pce barn door track I/N0652168
green spaghetti
gap filler
ozito nail gun
Dewalt drill
Ozito hammer drill
ozito laser leveler
hammer
Used a laser leveler to mark the height of rails on wall.
Drilled 6mm holes in the brick wall where wood rails would go, placed spaghetti in holes and fixed 30x18 pine for top rail and 42x18 pine on bottom of wall.
Cut 2.4m panel in half to make panel 1.2m high. Fixed panel onto pine rails using nail gun. Fixed 30x30 pine to top of panel to form frame.
- Step 2:
Used gap filler to fill in gaps. Painted the panels.
- Step 3:
Used laser leveler and marked the height of barn door rail. Fitted 65x18 pine beam where rail is to be fitted by using 6mm wall plugs.
- Step 4:
Got a friend to weld 3 one metre black barn door rails together. Grinded smooth and then sprayed with primer and then flat black paint.
Held rail along pine beam that has been fixed to wall, and marked where fittings go for steel barn door rail. Drilled 10mm holes in concrete wall, used the plugs and fittings with the barn door kit to fix rail to wall.
- Step 5:
Using template supplied, drilled holes in door to fix barn door runner to door.
Applied undercoat to doors and then gave two coats of enamel paint to finish the doors.
- Step 6:
Fitted Barn door runner to doors. Fitted doors to steel beam. Fitted stops to guide where door opens. Fitted guides to floor for doors.
