Our project transformed a neglected outdoor brick toilet into a unique and functional entertaining space. Using a grinder with a diamond blade, we cut a bar window and installed a lintel using timber framing repurposed from the original house, installed live-edge blackbutt timber bench and floating shelving, laid floating floorboards, added a beautiful Moroccan copper sink, shiplap lining and feature lighting. The exterior was refreshed with a whitewashed finish, while the roof and gutters were replaced. At the rear, we installed an outdoor shower that is screened by timber framing repurposed from the house. Blending craftsmanship, sustainability and creative design, we’ve created a welcoming backyard retreat that celebrates our home’s history.
VJ board
https://www.bunnings.com.au/easycraft-easyvj100-general-purpose-9mm-900-x-1200mm-mr-mdf-e0-primed-white_p0330843?store=7368&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB9SLSOf2Xq0uTFdOqbBJ9Jp3&gclid=CjwKCAjwvZHTBhAlEiwA1ug5P-2W109XMVEMBSE20zEr54IuSFde2hUqonqTJqwrVcSS84enDa0mVhoCDrgQAvD_BwE
Floating floors
https://www.bunnings.com.au/floor-select-8mm-2-13m-elysian-oak-laminate-flooring_p0336751?store=7368&gclsrc=aw.ds&gad_source=1&gad_campaignid=21112196286&gbraid=0AAAAADtbEB-oJ6hJUOsiBorXqkqBuMtkg&gclid=CjwKCAjwvZHTBhAlEiwA1ug5P9yqDJyE_-Ho48ljGsbq1pRVeawrg0tmSCM7zUCwRTxlUBQmOV6fixoC_LgQAvD_BwE
Lights
https://www.bunnings.com.au/brilliant-bloomsbury-11-5cm-diy-vintage-style-glass-pendant-light_p0277202
paint
https://www.bunnings.com.au/dulux-15l-vivid-white-low-sheen-wash-wear-interior-paint_p0638909
https://www.bunnings.com.au/dulux-4l-vivid-white-low-sheen-weathershield-exterior-paint-4l_p0144763
Melamine
https://www.bunnings.com.au/customwood-3mm-1200-x-600mm-white-mdf-backing_p0610151
flexible hoses
https://www.bunnings.com.au/enduraseal-250mm-silver-premium-flexible-braided-extension-water-connector-2-pack_p0422528
power point
https://www.bunnings.com.au/deta-x6-white-double-powerpoint_p4331856
Light switch
https://www.bunnings.com.au/deta-white-1-gang-single-vertical-switch_p4330979
No more gaps
https://www.bunnings.com.au/selleys-475g-no-more-gaps-interior-multipurpose-gap-filler_p1230010?store=7368&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB-Qph3f52gtw4hsR2rvgCJtg&gclid=CjwKCAjwvZHTBhAlEiwA1ug5P2fMy4QrxGcZ7k69E1TBbx2DduCCT6tehlpNe5aIyZqXiqCtc_NxhxoCXckQAvD_BwE
Screws
https://www.bunnings.com.au/zenith-8g-x-40mm-zinc-plated-hinge-long-thread-countersunk-head-timber-screws-100-pack_p2434150?region_id=117368&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB9SLSOf2Xq0uTFdOqbBJ9Jp3&gclid=CjwKCAjwvZHTBhAlEiwA1ug5P68F3NcpAlZXSEoEsxCh2Xbrc_2Q_UL7Z0GwHvvcqM36b8J9bUyN2RoCScoQAvD_BwE
9 inch grinder https://www.bunnings.com.au/makita-230mm-9-angle-grinder-ga9060k_p6240349
Cordless drill
https://www.bunnings.com.au/makita-18v-brushless-2-piece-combo-kit-dlx2283sm_p0090871
Tape measure https://www.bunnings.com.au/stanley-8m-tape-measure_p5660379?store=7368&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB80hDn1nSEuo5lQircwnJrSZ&gclid=CjwKCAjwvZHTBhAlEiwA1ug5P38g_CyTCLDnKCfUbFwykYax6aNsf1i3zCo_823XVgT0YuRrX9UA5BoC2HcQAvD_BwE
Level https://trade.bunnings.com.au/stanley-1200mm-high-impact-abs-resin-spirit-level_p5660383?region_id=117368&gclsrc=aw.ds&gad_source=1&gad_campaignid=23991061348&gbraid=0AAAAADtbEB-GUq7Nm-aVNRze5sfpWefzV&gclid=CjwKCAjwvZHTBhAlEiwA1ug5PywDiHXD9hdA5zm0P_wDqbhM1vWlXQsU6x1ERof-dsrP0ZK5hytPQBoCYeIQAvD_BwE
Screw driver
https://www.bunnings.com.au/stanley-2-x-100mm-phillips-head-essentials-screwdriver_p0127145?region_id=117368&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB80hDn1nSEuo5lQircwnJrSZ&gclid=CjwKCAjwvZHTBhAlEiwA1ug5P1w6G-JO-DiyyXXDuLk-UgCce_N58QNyy8v0hDrN85z_KyNuwuzVGhoCZkEQAvD_BwE
Paint brush https://www.bunnings.com.au/freeform-63mm-all-purpose-paint-brush_p0472233
Paint roller https://www.bunnings.com.au/paint-partner-230mm-10mm-nap-budget-roller-kit_p0328957
Club hammer https://www.bunnings.com.au/trojan-1-1kg-steel-club-hammer_p0131373
- We cut out the window and installed a timber lintel from repurposed 75x35 mm hardwood from original house frame.
- Step 2:
2. We framed up windows and installed them as an opening over the bar bench.
- Step 3:
3.We installed the timber bench and floating shelves.
- Step 4:
4. We installed the floating floors.
- Step 5:
5. We installed the VJ board and painted the inside of the bar area.
- Step 6:
6. We connected lighting overhead and installed a USB charged light system underneath the floating shelves.
- Step 7:
7. We replaced the existing roof tiles and gutters.
- Step 8:
8. We white washed the exterior of the outside bricks to refresh the area.
- Step 9:
9. We installed a sink inside and an outside shower on the rear wall of the building
- Step 10:
10. We screened off the outdoor shower by using repurposed timber hardwood framing from the original house.
