We updated our tired and dated kitchen to create a user friendly environment with more bench space. We also added some under bench top lighting to create a brighter space to work in. We changed the lay out to remove the high bench and make the area more open. We brought the dishwasher out of the laundry so that it was closer to the drawers where the utensils and crockery are stored.
Gyprock
kaboodle bench tops
Kaboodle cabinets
Kaboodle hinges
Kaboodle door handles
Kitchen sink -
https://www.bunnings.com.au/blanco-1160mm-stainless-steel-dinas-8s-right-hand-bowl-sink_p5110469
Structural pine
Cornice 55mm
MDF skirting board
Dulux wall and ceiling paint
Ryobi drill -
https://www.bunnings.com.au/ryobi-18v-one-drill-driver-starter-kit-r18dd22_p0715241
tile cutter -
https://www.bunnings.com.au/ozito-pxc-18v-tile-cutter-pxtcs-018-skin-only_p0800099
Full Bore concrete grinder -
https://www.bunnings.com.au/full-boar-2000w-180mm-concrete-grinder_p0122289
Ryobi multi tool -
https://www.bunnings.com.au/ryobi-18v-one-multi-tool-skin-only_p1024308
Ryobi circular saw -
https://www.bunnings.com.au/ryobi-18v-one-165mm-circular-saw-r18cs-0-skin-only_p6210595
- remove old kitchen
- remove slate floor tiles using the full bore concrete grinder
- rendered the walls
- electrician installed first fix
- assembled kaboodle cabinets
- installed kaboodle cabinets and bench top
- second fix electrician and plumbing
- tiling
- installed home made bulk heads built from pine and gyprock
- painted
