we wanted a splashback that was simple, timeless and easy to live with. the white subway tiles brighten the kitchen,complement the dark cabinetry and create I clean modern look without going out of style. we're really happy with how it finished and how it ties into the whole kitchen together.
practa solutions ceramic wall tiles 300 by 100 sub
wedge slippage system
dunlop premixed mastic tile adhesive
dunlop grout
dunlop silicone
1200 level
angle grinder
Notch trial
grout sponge
plastic bucket
microfibre
remove old vinyl planks clean up and make way for new tiles
install high-level line around kitchen to make a starting point
roughly marked wall with new tiles to make sure pattern would work
started tiling and adding wedge system as I went along
came in approximately half tile to start the brick pattern and wedges as I went
using the wedge system I could level the tiles out as the pattern go to the desired height
clean down tiles with hot soapy water to remove any of the access glue once it was dry
installed grout using grout sponge to put grout in joints clean down grout of tiles
PowerPoint to new locations so I would work with the new layout with the tiles
silicon up all remaining joints were needed with colour match grout
cleaned up and position everything back where are used to be
