My daughter and I took on a DIY project when we found a beautiful old small cabinet perfect for her many special miniatures she receives from Grandma's garden fairy. We were both keen to get started and living very close to Bunnings has its perks. We often take her pet chicken there with us to shop and buy baby chinos. This project took 4 days and my daughter was ecstatic with the results.
Rocket Timber Sanding Sheets – 8 Piece https://www.bunnings.com.au/rocket-timber-sanding-sheets-8-piece_p0335356?region_id=116310&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0yBptSXzzS62pTb1EGyZg_DMEl4QJUN0ZLploOa93n8ufrOtazxpRoaAu5sEALw_wcB
Cabot’s 250ml Maple Gloss Stain & Varnish — oil-based can .
https://www.bunnings.com.au/cabot-s-250ml-maple-gloss-oil-based-stain-and-varnish-250ml_p1520237?store=6310&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0zZsp2phiEV3UaprrJJpkIZmRMqbUOc6t9veDd27qbUXpDECcAdZyMaAmqfEALw_wcB
Poly Paint Stripper 250ml
https://www.bunnings.com.au/poly-250ml-paint-stripper-dcm-free-250ml_p0400163?store=6310&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0xfahpf4wvpyIubLGyldNihgESjyRFhI5cIaAZ5qE5e106qs3XJiXIaAsomEALw_wcB
Crystal Knob 30mm Clear,
https://www.bunnings.com.au/taskmaster-30mm-crystal-cabinet-knob-30mm_p0132824
Boyle 1.5m × 45cm Self-Adhesive Tropical Palm Leaves film,
https://www.bunnings.com.au/boyle-45cm-x-1-5m-tropical-palm-leaves-self-adhesive-film_p1662782
Dulux 300g Gold Bright Finish Effects Spray Paint,
https://www.bunnings.com.au/dulux-300g-gold-bright-finish-effects-spray-paint_p0782802
Practa Small Polymer Clay Project Kit
https://www.bunnings.com.au/practa-small-polymer-clay-project-kit_p0383636
Kincrome 14 Piece Kidcrome Kids Tool Set,
https://www.bunnings.com.au/kincrome-14-piece-kidcrome-kids-tool-set_p0631594
UNi-PRO 3 Piece Paint Brush Set,
https://www.bunnings.com.au/uni-pro-3-piece-paint-brush-set_p1661064?store=6310&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0yZRIw6x3dySaOb3vtkOECzjFQWQmbnyBPWw9IpnJPIIURYE1ycYRoaAk6zEALw_wcB
All Set Steel Wool Soap Pads - 12 Pack,
https://www.bunnings.com.au/all-set-steel-wool-soap-pads-12-pack_p4460951?store=6310&gclsrc=aw.ds&gad_source=1&gad_campaignid=20876642384&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0w_ucAMgzjoS68KCpwwI_QjIf3LysLe4CvOQLkw-RTJrWAhjbhZLt4aAp96EALw_wcB
All Set Microfiber Cleaning Cloths 20 pack
https://www.bunnings.com.au/all-set-microfibre-cleaning-cloths-20-pack_p0874306?store=6310&gclsrc=aw.ds&gad_source=1&gad_campaignid=20876642384&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0wYwsaYhBo9-KjksMFeSq5ik-kU1AQ_nO4VzmW-W8iCWFrRhLmogkEaApcXEALw_wcB
Trojan 250mm General Purpose Scissors,
https://www.bunnings.com.au/trojan-250mm-general-purpose-scissors_p0855498?store=6310&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0x3Goax5KDZxpN7w7YCuv7Mb2q61OPYKGUzkfFI538e8nvX-ESycO4aAslqEALw_wcB
Trojan 6 In 1 Multi Paint Scraper,
https://www.bunnings.com.au/trojan-6-in-1-multi-paint-scraper_p0093215?store=6310&gclsrc=aw.ds&gad_source=1&gad_campaignid=20293637741&gclid=Cj0KCQjw94bTBhDQARIsAN3vv0xd0jkHXSLvElRve1Z4MRFZu7ySITEDaMMq66QoP25d17_zDPlXV8caAmPjEALw_wcB
1. My daughter and I stumbled across a beautiful vintage children's cabinet painted very sloppy blue. We decided to bring it home and give it a DIY makeover.
First thing we got started on was scraping all the old paint off. We got as much as we could with the scraper multi tool.
- Step 2:
2. While my daughter Lucy was at kindergarten I completed the next step with the Poly stripper. It only took one thick coat brushed on and an hour later it scaped of super easy.
- Step 3:
3.Next we sanded and sanded some more till all the gorgeous hard wood was back to its glory. We even found an original clown illustration under the paint on the plywood backing.
- Step 4:
4. Cleaning and Staining were the next steps. I scrubbed the wood with steel wool soap pads and then cleaned the whole piece with a microfiber cloth and clean water. After 24 hours drying I applied one coat of the Maple stain and varnish on all hard wood and allowed another 24 hrs drying time.
- Step 5:
5. Going back to Bunnings so we could pick out some finishings like new knobs and something to cover the plywood with. Lucy and I with the help of her pet chicken ( Snowball) picked out some sparkling crystals knobs and some tropical leaves contact paper that I thought would be easy to install
- Step 6:
6. I cut out the tropical paper to the same measurements as the 4 cubbies and the 2 sliding panels . I made sure everything was dust free and stuck them all on like giant stickers, using my scraper multi tool to make sure all the corners were attached well. It only took one roll and I had
some spare.
- Step 7:
7. Attaching the new crystal knobs was simple . I poked a hole threw the vinal where the previous nobs were and Lucy helped me screw them in the small space.
- Step 8:
8. I painted the original blue hooks that we removed with Gold spray paint. One coat on each side.
- Step 9:
Last but not least we glued a few polymer clay ladybugs i had sculpted and painted.
- Step 10:
All finished super happy with the results and ready to fill with special things
