26 year old 82 sqm merbau merbau deck was becoming unsafe and needed to be replaced. We decided to rebuild it ourselves using ecodeck riverbank Red designer series using 3mm quick fix fitting.
I found this product at Bunnings Warehouse you may like: Ekodeck 137 x 23mm 5.4m Riverbank Red / Estate Brown Designer Series Composite Decking https://www.bunnings.com.au/applinks_p0109383?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink.
I found this product at Bunnings Warehouse you may like: Ekodeck 137 x 23mm 5.4m Riverbank Red Designer Edge Board Composite Decking https://www.bunnings.com.au/applinks_p0200715?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: Quickfix for Ekodeck 3mm 100lm Kit - Timber Joists https://www.bunnings.com.au/applinks_p0130268?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink There was an error displaying this embed.
I found this product at Bunnings Warehouse you may like: 140 x 35mm Outdoor Framing H3 Treated Pine 2.4m https://www.bunnings.com.au/applinks_p8032241?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: 190 x 45mm Outdoor Framing H3 Treated Pine 6.0m https://www.bunnings.com.au/applinks_p8032322?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: CAgroup 75mm x 20m Bearer Protector G-Tape https://www.bunnings.com.au/applinks_p0758234?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: Zenith M8 x 130mm Hot Dipped Galvanised Cup Head Bolt And Nut - Each https://www.bunnings.com.au/applinks_p2443458?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: Bremick Ultrafast 10g x 65mm Stainless Steel 316 T20 Trim Head -100 Pack https://www.bunnings.com.au/applinks_p0671165?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: Cyclone Knee Pads https://www.bunnings.com.au/applinks_p0122526?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink There was an error displaying this embed.
I found this product at Bunnings Warehouse you may like: Kango 115mm Segmented Turbo Diamond Saw Blade https://www.bunnings.com.au/applinks_p0069763?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: Kango 5mm x 110mm K4 SDS Plus Drill Bit https://www.bunnings.com.au/applinks_p6350702?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: Earl's 250ml Wood Hardener https://www.bunnings.com.au/applinks_p1585306?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink There was an error displaying this embed.
I found this product at Bunnings Warehouse you may like: Ryobi 305mm Dual Bevel Sliding Mitre Saw RMS305DB https://www.bunnings.com.au/applinks_p0189196?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink There was an error displaying this embed.
I found this product at Bunnings Warehouse you may like: Ozito PXC 18V Cordless Drill and Impact Driver PX2PAK-500 - Kit https://www.bunnings.com.au/applinks_p0299326?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: Kango 12G Adjustable Countersink Drill Bit Set https://www.bunnings.com.au/applinks_p0727536?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: Full Boar 19 Piece HSS M2 Drill Bit Set https://www.bunnings.com.au/applinks_p0563517?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: Craftright 300mm Combination Square https://www.bunnings.com.au/applinks_p5660591?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: Kango 4 x 90mm 1/4" Masonry Drill Bit - 5 Pack https://www.bunnings.com.au/applinks_p0727857?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: Makita 18V 165mm Brushless Circular Saw DHS680Z - Skin Only https://www.bunnings.com.au/applinks_p6240314?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
I found this product at Bunnings Warehouse you may like: Makita 240V 125mm 5” Angle Grinder GA5030R https://www.bunnings.com.au/applinks_p1072322?source=product_share&utm_source=bunnings&utm_medium=retail-app&utm_campaign=product_share&utm_content=pdp_deeplink
Old merbau deck was becoming usafe so we planned out
the size of the deck, check measurements and see what amount of Ecodeck required.
Order ecodeck from Bunnings and than start demolition and inspect current Joists
Replace and sister joists on complete 82sqm metre area, taped as well. Use wood rot hardener as well. Lots of trips to Bunnings...love it.
Replace all decking boards
Hello @jrronan
Welcome to the Bunnings workshop community. It's sensational to have you join us, and thanks for sharing your deck rebuilding project.
This is a fantastic transformation, and it's easy to see the care and craftsmanship that went into rebuilding such a substantial deck. The rich Riverbank Red boards look beautiful, and the new wide steps create a welcoming transition that ties the whole outdoor area together. I also love seeing your family and friends pitching in along the way, it really captures the spirit of a DIY project and makes the finished result even more meaningful. You've created a wonderful outdoor space that's perfect for relaxing and entertaining.
Thanks for sharing the progress photos, they really show just how impressive this rebuild has been.
